Old 8th October 2015, 04:19 PM
Default Power hook up
Today I was doing bits and pieces on the car and hooked up the charger that I have, anyway long story short by the time I had finsihed working on the car the battery was down to 10%.
So i have decided to buy a proper charger,
The problem I wish to overcome is how to connect said charger.
Its heavy duty at 25amps and I really would like the possibility of connecting it to the car without cables shut under bootlid.
So can anyone recommend something, I was thinking about trailer socket converted to suit my needs or something else under back bumper that can be easily connected too with the car locked.
Old 8th October 2015, 04:38 PM
47p2's Avatar
47p2 47p2 is offline
Is this any use?
Nite Blue 3.0L SE Quattro
Old 8th October 2015, 04:47 PM
Is this any use?
Didn't know they made them, its a great idea however its inly rated to 15 amps.
So may have to go custom on it.
Old 8th October 2015, 06:35 PM
I was going to suggest something like this located discretely under the car -
http://www.ctek.com/gb/en/chargers/C...%20M8%203%2c3m
It has a rubber cover that bumps into the charger hole. But it's only rated to 15A by the looks of things so maybe not suitable either
Old 8th October 2015, 07:32 PM
15 amps at 240V so you will be fine at 12V.
Old 8th October 2015, 07:39 PM
Hmmm, maybe not, amps are amps. How many would you be putting through it?
The voltage relates more to the external insulation rating, the current capacity is about the conductors/contacts and resistance.
Old 8th October 2015, 07:40 PM
Erm, I think you may have that backwards - 15A at 240V is ~300A at 12V
In any case your 25A charger will probably only push 1-2A when charging, less if the battery is already fully charged. The 25A will likely only be in a "supply" mode, check the manual to be sure but I can't see it being a limiting factor on using a tow hook to keep it topped up.
Old 8th October 2015, 08:29 PM
Yeah its a shame that its not rated to 25 amp
Its 12v on the part, it has eyelets for battery connection
Yes the battery may only pull a few amps when it has a state of charge higher than flat but its not a good idea to build something on the principle, one day it might need the full 25amps and then there would be problems.
I have trawled the net this evening and not really found anything that I like yet other than stuff on alibaba that has min order restrictions.
I shall continue on my search.
Old 8th October 2015, 08:38 PM
What about a 110v socket? High IP rating if it's to be hidden under the rear bumper.
Matt
Old 8th October 2015, 09:12 PM
Bit large init?
