Old 8th October 2015, 08:29 PM
I was going to suggest something like this located discretely under the car -
http://www.ctek.com/gb/en/chargers/C...%20M8%203%2c3m
It has a rubber cover that bumps into the charger hole. But it's only rated to 15A by the looks of things so maybe not suitable either
Yeah its a shame that its not rated to 25 amp
15 amps at 240V so you will be fine at 12V.
Its 12v on the part, it has eyelets for battery connection
Hmmm, maybe not, amps are amps. How many would you be putting through it?
The voltage relates more to the external insulation rating, the current capacity is about the conductors/contacts and resistance.
Erm, I think you may have that backwards - 15A at 240V is ~300A at 12V
In any case your 25A charger will probably only push 1-2A when charging, less if the battery is already fully charged. The 25A will likely only be in a "supply" mode, check the manual to be sure but I can't see it being a limiting factor on using a tow hook to keep it topped up.
Yes the battery may only pull a few amps when it has a state of charge higher than flat but its not a good idea to build something on the principle, one day it might need the full 25amps and then there would be problems.
I have trawled the net this evening and not really found anything that I like yet other than stuff on alibaba that has min order restrictions.
I shall continue on my search.
Old 8th October 2015, 08:38 PM
What about a 110v socket? High IP rating if it's to be hidden under the rear bumper.
Matt
Old 8th October 2015, 09:12 PM
Bit large init?
Old 8th October 2015, 09:15 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Socket in the fuel flap?
No wait!!
Bumper is the best place but it will get covered in crap.
He bumper is the best place I think.
There is already a hole directly behind the bumper near the battery.
[center]
06 3.0TDI Quattro:
Options:
Old 8th October 2015, 10:33 PM
No wait!!
Old 8th October 2015, 10:41 PM
ScottD3's Avatar
Be ok if it was a diesel.
Your tow socket idea was possibly the best but if my socket was anything to go by, it's going to get wet.
[center]
06 3.0TDI Quattro:
Options:
Old 8th October 2015, 10:45 PM
I'm thinking about fog light cover for connection
with one of these
http://www.ebay.co.uk/itm/SD20-20mm-...3D191679655350
Old 9th October 2015, 07:56 AM
with one of these
be aware that you need something rated at 25A 12V DC, the connector you listed here is 25A @ 240VAC and would be I suspect massively under-rated. The same goes for the suggestion of any mains connector - whatever you do make sure it is properly fused
