Old 27th September 2015, 04:18 PM
thebluewhale's Avatar
Update:
Calipers - provisionally sold
Used RS4 Discs -provisionally sold
New Pagid pads for the above- provisionally sold
Megs G220 DA polisher - SOLD
Solar sunroof with loom and relay - SOLD
VCDS Genuine Ross Tech Hex Can lead. - available
S8 GTX number plate. - available
Reversing camera.... available
...and a Noggy blue D2 S8 sometime in the next 12 months.
A fully refurbished steering rack for a D2 - available
2 x PDCs (brand new boxed) - Part no. 4BO 919 275 - available
B6/B7 RS/S4 Rear Dust Shields/Splash Guards (brand new never fitted) - available
Part nos. 4FO 615 611/612
and
B7 RS/S4 Front Dust Shields/Splash Guards (brand new never fitted) - available
Part nos. 8EO 615 311/2 D
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 18th October 2015, 07:41 PM
Update:
8 Pot Brembo Calipers - NOW Available
New Pagid pads for the above- NOW Available
and
Old 19th October 2015, 08:34 AM
Thought the callipers had sold ...
Hmmm, could be tempted.
What's involved in fitting them to a FE D2 S8? I assume at the very least I would need a compatible set of discs and pads?
Old 19th October 2015, 05:01 PM
I have done this mod. You will need the disks, calipers and pads pluss an adapter bracket which Steve may have. If not Steve (Trophy888) can machine a set up for a small liquid consideration from Scotland, possibly, maybe!
Old 19th October 2015, 05:21 PM
Yep...got the adapter bracket and spare bolts as well
Old 19th October 2015, 06:26 PM
Ok thanks
... so I'd just need the discs and pads, yeah?
So would that be any discs and pads suitable for an RS6?
And what is the bracket for?
Old 19th October 2015, 06:47 PM
Ok thanks
I've got pads. The discs are worn out but the bells are still useable.You could always buy Phaeton discs as a cheaper alternative.
As the 8 pot caliper is huge compared to the 4 pot and the discs are bigger you need an adapter to bolt the caliper to.
Old 20th October 2015, 01:29 PM
Very tempted ...
So, to get an idea of cost, what size discs am I looking for, or would any that fit an RS6 or Phaeton do?
And you have the brackets and pads ... what about the dust covers/guards? ... and would I need anything else?
Old 20th October 2015, 07:33 PM
I think anything 365mm and above.
You could fit 390mm if you want. RS4 or Phaeton you'll be looking for to make it easier.
Got brackets and pads.
Don't know about the splash guards I'm assuming they have to go or be modified.
As I've never fitted them I don't know if you need anything else.
Mike (Conan) may be able to advise?
Old 20th October 2015, 09:11 PM
With the calipers, the adapters and a set of pads (I use Ferodo DS 2500) you will need disks from a C6 RS 6 or B7 RS4 or possibly a Pheaton. I use AP racing disks (they need their own bells). With those parts just fit, test and re-attach your retinas!
