Old 21st October 2015, 08:19 PM
This any good to you? I found it on ebay, complete Bose D3 amp, sub, speakers. £160
http://www.ebay.co.uk/itm/291570894293
Matt
Old 22nd October 2015, 07:07 AM
Chaz Chaz is offline
Thanks. I spotted that too and was going to ask, could I fit with as a straight 'hot swap' without coding or anything like that?
If so, I might do this instead as an interim measure.
Old 22nd October 2015, 08:28 AM
The Amp will need Component Protection removed so it can be used in your car. Main Dealer may do this, or a specialist with the correct software. Price is around £60~£75
Matt
Old 22nd October 2015, 08:39 AM
Here's some info on the differences between the systems.
ID:	12000   Click image for larger version
Matt
Old 22nd October 2015, 01:11 PM
Thanks. Appreciated.
Old 25th October 2015, 08:45 PM
Lee S Lee S is offline
Watching this with interest as mine has the standard system (ie non-Bose or B&O). I'd like to make it a touch better too. I wonder if there are better drive unit/s that can just be swapped for the original drive units? I can't be arsed messing with the amps and wiring etc, but swapping drive units out is do-able I guess.
Lee
2017 Nissan Leaf Tekna
Old 26th October 2015, 08:59 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Have you considered the almighty retrofit of B&O? If you're handy with the fiddly bits and willing to invest time and money. Recently on eBay there was a complete system in Germany for £1k
I've not heard the B&O from the D3, but it is arguably the finest audio set up in a production car. Where better to start?
If the B&O kit could have been retrofitted without what I imagine would be lots of specific interior dash, door trim I'd have bought the thing myself!!
2007 Mini Cooper S R56
Old 26th October 2015, 05:24 PM
I suspect I would although I currently have a very decent amp (DLS A7) and some CDT speakers, both of which should match or be better than the B&O stuff. As this is paid for already, 'all' I need is the Mosbridge unit. But as I know my front speakers are too small, I need to use them with spacers (which I can mill on my own machine) or buy 6.5 inch speakers, probably Audison Voce or Morels ..... then its a spending spree and could quickly add up to the cost of a 2nd hand B&O system.
Actually, perhaps I should listen to a B&O system, anyone near Ickenham, Middlesex that I could ask for a quick demo?
Old 26th October 2015, 05:27 PM
I think this should be the case. What I might do is retrofit the front speakers first but they are only 5.25inch and will need some work to make an adaptor for. I suspect they will want more power than the amp can produce, but happy to test this theory and give some feedback. If the weather is nice this weekend and I dont have such a hectic week like last week, I may have the energy to try this.
Old 26th October 2015, 05:28 PM
Off Topic, your steeringwheel upgrade, do you know if I can just add these to my 'normal' steering wheel?
http://www.ebay.co.uk/itm/Audi-A3-A4...QAAOSwKIpWE8ki
If so, where do the paddles attach to, cant feel anything except a hole which I believe will be for the wiring / cabling.
Thanks
