Mot'd today and clean bill of health for another year
![]() Not been using it much though and still have the glow plugs to sort out, oh and now a coolant temp sensor that I think has been a cold starting issue I put down to the a5 injectors ![]() Been pottering around in a Mondeo Zetec S estate tdci for a month or so now, great work horse, it's a pain to get the A8 out from where it's stored at the moment so been using the Mondeo on weekends too, but as I got it out for mot today I'm going to enjoy it for the rest of the day ![]()
Get of the forum and go out and enjoy then
. Nite Blue 3.0L SE Quattro |
Good job man , we used to do alot of this type of work , heads off vehicles that know other garages wanted to take on , there just so long winded though and it was hard to get your hours out of the job , loads of time is cleaning faces and getting old gaskets off and so on as you know , well done for sticking at it.
With the glow plug issue , do the glows actually do a timed flash when the engines cold , loads of the common rail stuff especially with piezo injectors they don't even do a flash or don't flash until the temp goes under -6 degrees or such like , I believe they can flash on the over run or for use when the engine goes into regen modes , suppose if you want rid of the flashing glow light they would have to be done or pull the reporting wire out of the glow relay . We have a mobile engineer bloke who we call out if we get snapped glow plugs or other broken studs and the likes ,don't know whether you ever worked on Merc cdi diesels , they have a great long 6mm diameter torx key that hold the injectors in , it's about 80 mm long , there a bassa for snapping off in the head , I've seen him drill all the way down it stepping up sizes till its at the original thread , if I tried it would just be broke drills jamming up the hole ! Good post , keep us informed how it settles down |
I took your advice and we popped out and enjoyed it some more, also Saturday I got it out again and went to scarefest at Alton towers in it, it made the journey so much more tolerable, you just melt in the 8's seats
![]() It's very time consuming, it swallowed up 5 long days and even though I could of skipped quite a bit and fitted it back dirty, whilst I was doing it I may as well of got it all cleaned up too, and it'll help it run better in the long term as your aware ![]() The glow plugs I was under the impression they where used for a cleaner start up and also "afterglow" so continue to run for a few minutes once started, I'm not sure though, I'm apprehensive of taking out the other side as if one does break by accident the other head will more than likely come off, either that or a bore scope and a vacuum with a small hose attached but it's not guaranteed to get everything out. I have all the new beru plugs at home waiting to be fitted, and a can of plus gas and I'll just take my time, I was going to do it the weekend but I was tired and I need to be 100% on the ball to do this job, I can't live with the flashing light, and I couldn't just trick it to thinking it's ok neither, so new metal plugs and a software flash are my only options ![]()
So the glows do do a flash, fair enough, im sure you will get them glows out , folk say get the engine hot and try but i found with the vauxhalls with the fiat engine there a bassa for snapping in the head , i found a stone cold engine was better for getting them out , its just 'feel' thing and work them back and to if they start to fire up in the thread coming out .
You have taken heads off it , sure you will do the glows no worrys ![]() |
Still not plucked up the courage to do it yet, plus iv been really busy doing nights and other stuff, iv got the plugs sitting in the house at the moment all ready for fitting
Well time for an update, I got the courage together and got all the glow plugs changed, I was bricking it as the last thing I wanted was the car off the road again, I pre soaked them in plus gas a few weeks ago, when preparing to take them out, I took the car for a nice run and got it nice and hot, ran the glow plug circuit with VCDS to try and burn off any deposits as per the tech dump, re soaked all the plugs in plus gas and set my 1/4" torque wrench to 20NM and crossed my fingers, they came out without a hitch
![]() Anyway a picture of the offenders, note the white ring and wider tip that denotes they are ceramic, also with the fact that even the slightest knock means they are scrap, the other metal plugs are from the cylinder head I replaced. ![]() Not done much else to the car to be honest, now it's not my daily i'v been gagging to give it a good valet and whack some poorboys black hole and seal it in but not having the car at home at the moment makes it more difficult unfortunately ![]() Be nice when I can finally have it on the drive and actually get to use it more ![]()
