Old 26th October 2015, 05:54 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Originally Posted by Chaz View Post
Off Topic, your steeringwheel upgrade, do you know if I can just add these to my 'normal' steering wheel?
http://www.ebay.co.uk/itm/Audi-A3-A4...QAAOSwKIpWE8ki
If so, where do the paddles attach to, cant feel anything except a hole which I believe will be for the wiring / cabling.
Thanks
Someone more qualified than me would be best to advise you mate. What wheel do you have just now? Replacing the wheel with the functionality you want is the conventional way to go. It's so quick and simple I was able to swap it, and code it!
2007 Mini Cooper S R56
Old 26th October 2015, 07:32 PM
Chaz Chaz is offline
A discoloured brown wheel with no paddles
Old 26th October 2015, 07:49 PM
Johnmed's Avatar
No brainer then, for similar money you can get yourself a MFSW with paddles. Learn from my mistake (I knew within minutes of buying the wheel) and get one with the same number of spokes as your current wheel so your existing airbag will fit it. Then if you have VCDS and a large enough (T55 I think it was) torx bit it really is a simple job.
Old 27th October 2015, 07:00 AM
Any suggestions on best / cheapest place to buy VCDS?
Thanks
Old 27th October 2015, 07:07 AM
Johnmed's Avatar
Thanks
The club can only recommend the official genuine software and cables, these cost about £300 I believe, and hold their value incredibly well. RossTech support these devices very well, you get what you pay for and there's frequent updates I hear.
I on the other hand may have a non genuine cable and software which may have been bought for about £10-15 on eBay or some such site.
Really, unless you want to be best friends with your local Audi stealership, having your own VCDS is essential.
Old 27th October 2015, 07:11 AM
Johnmed's Avatar
One like this should float your boat?:
http://www.ebay.co.uk/ulk/itm/281829383558
Old 27th October 2015, 08:55 PM
Yep, in brown however Wished the car had black interior but sadly not.
Thanks
Old 27th October 2015, 08:59 PM
Johnmed's Avatar
This:
http://www.ebay.co.uk/ulk/itm/281404648750
Any good?
Old 28th October 2015, 12:23 PM
I cant remember how many spokes my wheel has. Will check later, thanks.
Old 1st November 2015, 05:42 PM
So, lots of vibrations.
Exhibit A.
https://www.youtube.com/watch?v=WqOuMtkcN0o
Add some sticky metal stuff.
Ah, that's better.
https://www.youtube.com/watch?v=fuCq1EpuR9Y
Less vibration. I also put some on the rear shelf itself and then from underneath as the rubber that touches near the sub vibrates too.
