Do you have access to a digital thermometer so you can take readings straight off the engine before you go down the route of pulling it to bits.
Just wondering if the sensors borked.
Del ![]() |
I do have a type K thermocouple wire I can use on my dmm. Where should I probe?
2003 A8L Build Thread D3 Turbine Reps – S8 Mani 2002 Allroad Build Thread 2005 Color Match - TDI 01E - TTV LWFW - RS4 PP - BW K04s - Stg 2 WMI - WB- AWE DTS - EFK - H-SPORTS - IPP Arms - S6 Alcantaras - 4K LB Hitch - V1 |
in the coolant stream would be good but can you get it on the block close to the thermostat?
Del ![]() |
I may be able to put it on the metal thermostat housing
Tags |
coolant, high coolant temp, thermostat |
