Old 23rd May 2015, 08:36 AM
Since you've got no fault codes, sounds to me like the bleeps are the normal 'obstruction' bleeps and that the system 'thinks' there's an obstruction because a sensor in misbehaving enough to cause a false positive but not enough to trigger a fault code.
My guess would either dirt/moisture, as Neil suggested, a partially failed/failing sensor or damp/dirty connector.
I've had to chop off and replace a couple of my front sensor plugs due to moisture and corrosion. It's possible one of yours may at the early stages of that; not enough to cause an open circuit but enough to interfere with the signal.
I'd take the bumper off and check/clean the connectors. Might be worth buying a spare sensor or two beforehand in case it turns out to be a failing sensor.
Old 26th May 2015, 08:40 AM
A job for after the meet!
I checked the measuring blocks, and they're all exactly the same, so still no clues.
Old 2nd June 2015, 09:14 AM
And now the problem has gone away!
Old 2nd June 2015, 09:25 AM
I'd say almost certainly caused by contact moisture/corrosion in that case. The engine heat from the journey has probably dried the contacts out.
Old 31st October 2015, 08:29 AM
oldnick oldnick is offline
well the sensors on mine are just ornamentation , ie , engage reverse , makes noises , nothing works except the light on the switch flashes
so that means there is a faulty sensor somewhere ? does one u/s fail the whole system ?
no VCDS around here .... maybe when I move to southampton next year there will be some kind soul with one in easy reach !
Old 31st October 2015, 08:35 AM
Yes, that's it exactly. One faulty sensor and the whole system fails. Only a VCDS will tell you, unless you can be bothered to replace one sensor at a time until it's fixed.
Old 31st October 2015, 09:53 AM
Originally Posted by oldnick View Post
no VCDS around here
If anyone is desperate I have an ancient laptop that I used to run VAG-COM on (for many years), complete with serial OBD-II lead. Free to a good home!
It's battery is dead so you have to run a long mains lead out to the car, but apart from that it works fine. IBM ThinkPad of some variety, built like the proverbial brick privy so almost indestructible, running Windows ME.
Has various versions of VAG-COM on the disk. One of these was properly registered and most definitely worked, but I deactivated it to upgrade to VCDS-Lite on a Windows 7 laptop.
Also has VCDS-Lite installed but not tested. If anyone is interested I'll plug it in and check that works OK, I expect it will.
As you presumably know the unregistered version of VCDs is still pretty useful.
If you can't be bothered with a mains lead you can probably buy a power adapter that will generate the 16V DC it uses and plug into your car 12v power outlet. I have one for my W7 laptop (Dell 19.5v) and it's quite handy, not least because the laptop then runs in mains power mode so doesn't keep trying to dim the screen or shut things down (and yes, I know I could override that).
Maybe I should stick this in the VCDS section?
Old 31st October 2015, 11:04 AM
Now tested, works fine. Looked at the "usual suspects" (no auto-scan as it's unregistered) on my car and found and cleared the usual (largely irrelevant) errors.
One good thing about ME is that it only takes a few seconds to boot.
And the battery isn't quite dead, it will boot and run for a few minutes.
Old 1st November 2015, 10:02 AM
sounds like a good offer , and would be really handy for me !
expect to be back in the uk before year end so can I take you up on that ?
being a motorhomer I have the 12v power supplies so would certainly have no problems in that direction
had a look on the map for HS2 , doesn't seem to be shown ! where are you ? my daughter is often around denham , does it go in that direction , seem to remember some connection with birmingham !
Old 1st November 2015, 03:08 PM
Denham is fairly close to me (less than 10 miles away and I drove by it earlier this afternoon).
I'd like to be shot of it fairly soon so can your daughter pick it up sometime?
(Also advertised on another forum but the responses are less, how can I put it, "inviting". )
