Old 30th October 2015, 08:07 PM
Default Reinforced Timing Belt
Has anyone here tried these?
http://store.034motorsport.com/timin...rs-t297rb.html
Old 31st October 2015, 03:27 PM
Dave McB Dave McB is offline
I didn't even know they existed - however the company I work for has an account with Gates - I shall attempt to check it out on Monday (although Gates are murder to try and get the right department - such a huge multinational company)
Old 31st October 2015, 03:39 PM
Me neither. Just stumbled on this one while looking for something else.
I'm thinking I might get one for my next major service, assuming that they are indeed stronger and last at least as long as a regular belt.
Old 31st October 2015, 05:15 PM
Did not see in that link what material they are made of. Regular belts are mostly made with nylon fibre, some aftermarket add glass fibre for extra strength and then there is kevlar fibre on some as well.
As far as I know they do not extend service life, they are just stronger. As they are meant for race engines they would be changed a lot more often and might even have shorter life. Unless you have high lift camshafts or significantly increased top rpm just stick to regular belts. Basically the way I see they are meant to take a lot of stresses but not necessarily to last long. Look at the racing tyres - they give plenty of grip but you cannot do 20k miles on them.
Old 31st October 2015, 05:43 PM
That's what I was wondering, and why I asked. If that is the case I'll stick to regular belts.
I figured they might be worth considering, but only if they had greater strength AND an equal or greater longevity. While it's rare for timing belts to snap within their service life, it would be good to reduce that risk even further.
EDIT: I can't find anything that specifically states the service life of these belts, but everything seems to suggest that they may be roughly equal to regular belts in that respect:
http://www.gates.com/products/automo...e-timing-belts
To avoid costly engine repairs, follow the auto manufacturers’ mileage replacement recommendations or we recommend timing belt replacement at around 60,000 miles.
https://www.youtube.com/watch?v=3sEsyU4S07g
I did notice this though:
http://949racing.com/Gates-racing-ti...elt-miata.aspx
Note: This belt squeaks loudly on startup and when cold. Not a good idea for a daily driver if noise bothers you.
Think I'll give them a miss. I guess there had to be a downside!
