Old 27th November 2015, 12:40 PM
zahg zahg is offline
Default Winter defrost while car locked hack?
Hi on my previous A8 2006 model I was able to start engine keylessly and get out of car and lock it using the soft close button on the door handles - great for unattended warming/defrosting car on winter mornings.
On my current A8 2007 model where only one of the soft door lock buttons work, I'm not able to lock the car with engine running. Was this a strange fault with my previous audi that allowed this? Or is there a VCDS hack to enable this?
thanks
-zahg
Old 27th November 2015, 01:46 PM
My 2006 is the same as your 2006 and I do as you did - here is my coding...
Code:
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.LBL
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H08 0160
   Revision: 01604808    Serial number: AUX3Z0EN380732
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58B401C5EB45FDE177B-800D
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
Code:
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.LBL
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: T¸rsteuer.FS BRM003 0100
   Coding: 0028462
   VCID: 20446925F39575214FB-8075
Old 27th November 2015, 01:55 PM
Witchfinder's Avatar
Witchfinder Witchfinder is offline
I had the joy of getting in my frosty car on Monday, and having the heated windscreen clear it in under a minute. Far better than the heated screen on my old S-Max.
Rob
2013 Audi A7 BiTDi, with Tech Pack High.
2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold **
Old 27th November 2015, 04:21 PM
Thanks snapdragon, I'm just a beginner on the whole VCDS thing but here is my codings for my old 06 and new 07 A8s.
Audi 2006:
Code:
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0ED382601
   Coding: 0412672
   VCID: D8B964A86B9AD6DE037-808D
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 1940
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Coding: 0028462
   VCID: 20498C48F34ADE1EBB7-8075
Audi 2007:
Code:
   Revision: 01904910    Serial number: AUX3Z0G2318326
   Coding: 0412672
   VCID: 58B9E4A8EB9A56FE45-800C
   Component: ELV                 1940
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: T¸rsteuer.FS BRM005 0180
   Coding: 0028462
   Shop #: WSC 02313 785 00200
   VCID: 20498C48F34ADE3E7D-8074
There are some differences (even between our 06 models) but I don't understand enough to know what exactly would allow the engine on door lock.
cheers
-zahg
Code:
   Coding: 0412672
   Component: ELV                 XXXX
Code:
   Coding: 0028462
Old 27th November 2015, 08:01 PM
Will it lock on the fob as appose to the soft close button
Old 27th November 2015, 10:28 PM
No only on the soft lock buttons.
Old 29th November 2015, 12:12 PM
Does your car have the auxillary heater ?
Old 29th November 2015, 01:50 PM
Don't think so, not sure what that is how do you tell?
Old 29th November 2015, 07:48 PM
Do you have 'set up ' on the climate panel go into that can you see aux heating option , if it has you can do a modification to put it to a timed function but you need to fit a auxillary water pump and a couple of pipes to the aux heater unit and do some coding . There's a thread on it somewhere .
I have done this to my car ( 4.2 tdi ) it's superb , I set it for 30 min run before I go out in the morning , all windows demisted and the cars toasty warm inside , one of the best mods to do on the car in my opinion
Old 29th November 2015, 09:53 PM
Sounds like a really nice feature, but never saw any option for it in the mmi setup.
