Common fault on the front is upper [inner] side... but as others suggested it could be related to several points incl. notorious [as in annoying] anti roll bar bushes.
I'd suggest to take it to a 'decent' mechanic to have a look and inspect this for you and isolate an issue... FYI, I recently replaced all of them on mine and you'd be looking @ @450 for parts [OEM Lemforder] + 100ish for labour. And you'd need tracking so all in all should come to around 700ish GBP.
Expensive but worth the job if you are planning to retain the car
Hope that helps...
