Old 16th January 2016, 10:11 PM
Scottnybottny Scottnybottny is offline
Default Intermittent ESP Warning
Hi all,
I'm hoping that someone out there has had experience of this issue and found a way to overcome it. I have been experiencing an intermittent ESP warning for a few months now which is really bugging me. Sometimes the warning will flash 3 times and disappear for the rest of the journey other times it will illuminate and stay on for my entire journey. I have once managed to quickly scan it and catch the code which can be seen below in the ABS section:
Sunday,20,September,2015,16:37:53:07419
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech
License Plate:
Mileage: 146370km-90950mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0F 11 31 15 16 17 18 19 1E 25 28 34
36 37 38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77
Mileage: 146370km-90950miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 A HW: 4E1 907 409
Component: 4.2L V8TDI G000AGMª0070
Revision: --H01--- Serial number: AUX3Z0E9376803
Coding: 0011773
Shop #: WSC 00783 210 84012
VCID: 224BBD6DFDD30A2E6B-8076
2 Faults Found:
000408 - Engine Oil Temp. Sensor (G8)
P0198 - 000 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 146189 km
Time Indication: 0
Date: 2015.09.18
Time: 11:07:11
Freeze Frame:
RPM: 1155 /min
Torque: 237.9 Nm
Speed: 4.7 km/h
Duty Cycle: 31.6 %
Voltage: 14.36 V
Temperature: 21.6°C
Temperature: 79.2°C
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 146190 km
Time Indication: 0
Date: 2015.09.18
Time: 11:08:07
Freeze Frame:
RPM: 1428 /min
Torque: 183.3 Nm
Speed: 40.1 km/h
Duty Cycle: 25.6 %
Voltage: 14.44 V
Bin. Bits: 00101000
Torque: 230.1 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 P HW: 09E 927 156 B
Component: AG6 09E 4,2lTDI RdW 0030
Revision: --H01--- Serial number: 0070556
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 306F4725A33FA8BEED-8064
1 Fault Found:
009783 - Torque Management Feedback Signal A
P2637 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 40
Mileage: 146189 km
Time Indication: 0
Date: 2015.09.18
Time: 11:07:14
Freeze Frame:
RPM: 1408 /min
RPM: 864 /min
RPM: 352 /min
(no units): 8.0
(no units): 54.0
Temperature: 59.0°C
T.B. Angle: 30.2°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0E9376803
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFDF85EB0F90FE45-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 11
Mileage: 146144 km
Time Indication: 0
Date: 2015.09.17
Time: 17:07:54
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 2447BB75E7C7041E19-8070
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300JK057560615
Coding: 0000002
VCID: 2E53595DB90BBE4EFF-807A
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318J.057516748
Subsystem 3 - Serial number: 7426.10.0500000000218B0164ÿ
Subsystem 4 - Serial number: 8B0164ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000078944
Coding: 1136657
VCID: 1C378395DFB73CDEA1-8048
2 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 146156 km
Time Indication: 0
Date: 2015.09.17
Time: 15:00:06
Freeze Frame:
Voltage: 11.40 V
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 146156 km
Time Indication: 0
Date: 2015.09.17
Time: 15:00:06
Freeze Frame:
Voltage: 11.40 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0143121
VCID: 31694221A835A1B6E2-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 B HW: 4E0 035 563
Component: DAB-Tuner H41 0700
Revision: 00000001 Serial number: KE1229T7900209
Coding: 0000001
VCID: 2345B869E2C9032660-8076
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0070
Coding: 0011773
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P000848C
Coding: 0431707
VCID: 275DAC7996F1EF063C-8072
Subsystem 1 - Serial number: 63328RB400BD74DF+
Subsystem 2 - Serial number: 63428RB400BD74D3U
Subsystem 3 - Serial number: 63528RB400BD74A2R
Subsystem 4 - Serial number: 63628RB400BD7547S
Subsystem 5 - Serial number: 63729RB400BE4C47Z
Subsystem 6 - Serial number: 63829RB400BE5A32T
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C1E671AC7D3D16CE-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3EN000475
Coding: 0000413
Shop #: WSC 34263 001 1048576
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 146190 km
Time Indication: 0
Date: 2015.09.18
Time: 11:08:09
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0110
Revision: 0000000C Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B858DD58342EEB3-804E
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000305A2180CA
Coding: FCFEFFDE2B7D04
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 13
Mileage: 146156 km
Time Indication: 0
Date: 2015.09.17
Time: 17:04:47
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 13
Mileage: 146156 km
Time Indication: 0
Date: 2015.09.17
Time: 17:04:47
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8004211
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 11
Mileage: 146144 km
Time Indication: 0
Date: 2015.09.17
Time: 17:07:54
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000033564
Coding: 0000000
VCID: 61C9F261B855513632-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FAF459BEFE07E35-807C
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4063338
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H46 0850
Revision: 00000000 Serial number: 364JR057501185
VCID: 3B7560097A795BE648-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000528000092
Coding: 0035972
VCID: 1D318E91C4AD35D656-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032622
VCID: 204FB765F3DF183E7D-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040511020220
Coding: 0004317
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 41
Reset counter: 17
Mileage: 146192 km
Time Indication: 0
Date: 2015.09.18
Time: 11:23:55
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 N HW: 4E0 035 223 E
Component: DSP-High D3 H02 0050
Revision: PROD_01 Serial number: 00000000778000
Coding: 0000023
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000072415
Coding: 0010101
VCID: 1E33899DC9AB2ECE4F-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001031
Shop #: WSC 00762 210 91493
VCID: 1F4DB499CEA127C644-804A
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Coding: 0000006
VCID: 3D716E11646D55D676-8068
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 304JQ057610774
Coding: 0000001
VCID: 2959AA4180E5D9762A-807C
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 C
Component: TV analog TUNER H14 0270
Revision: 00000040 Serial number: 00000000021122
Coding: 0000003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000004689
Shop #: WSC 00654 210 60455
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1234567890
Coding: 344530393135313035412056413031323334353637383930
Shop #: WSC 00762 210 89838
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032622
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 K HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0600
Revision: 00000000 Serial number: 00000510130360
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032622
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 233
Mileage: 146144 km
Time Indication: 0
Date: 2015.09.17
Time: 15:00:04
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720529302617
Coding: 0201108
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H13 0580
Revision: 00000000 Serial number: 00000007588199
Coding: 0010900
VCID: 2541A671ECFDFD160E-8070
End-------------------------(Elapsed Time: 04:02)--------------------------
I am hoping that the oil temp sensor is throwing up the error and I will get this addressed. Thank you in advance for any suggestions/experiences as it will discourage me from playing part swap roulette hoping to fix it!
I have searched high and low for an answer but solutions on other vehicles vary and some D3 experience would be great.
Many Thanks,
Scott
Old 17th January 2016, 05:40 AM
There is no logical connection between oil temp sensor and ESP light. It's to do with:
1 Fault Found:
Basically ESP ECU is not getting torque values back from engine ECU or they are out of range, it could be either communication issue between ECU's or more likely engine ECU cannot calculate torque value and send it to ESP ECU because of dodgy MAF for example or throttle body, or maybe engine ECU does not get load signal from ancillaries like AC or alternator.
Old 17th January 2016, 04:39 PM
Mmmmmm , engine torque signal may be reduced due to engine thinking engine oil temp is to high .... it's defaulted to a safer map as safe guard
Gearbox ecu will pick up on this on the network from engine and pass fault over to abs / traction
Very often any engine management issue the traction and cruise control will be disabled
Jag xf diesels have similar issue but other way round , gearbox oil temp sensor shows oil temp to high and defaults engine to a safer map ... not full limp though but you can feel some power loss , cruise and traction get disabled also
Not 100% with the Audi but could be a possibility
Old 17th January 2016, 07:09 PM
Thanks for the replies gents, makes sense now.
I haven't experienced any loss of power or disabled cruise control though!
So if I'm looking at the MAF's or TB's is there any logging I can do or tests I can perform to isolate the part at fault? I can clear the fault codes but they return so does it require any type of dealer reset that my full copy of VCDS cannot do? Reset the throttle bodies if that'll help.
Old 17th January 2016, 07:37 PM
My first port of call would be to get rid of that oil overheat code , I would of thought that the engine and gearbox program will not like to see that code
Old 17th January 2016, 07:51 PM
The date and time stamp are quite a few months back is this a report from a while back ??
Old 17th January 2016, 08:09 PM
Yes this was a scan from just a few weeks after I purchased the car privately.
I will clear all codes and take a drive so that you can see the reoccurring codes
Old 13th March 2016, 06:21 PM
Default Update
Sunday,13,March,2016,18:54:57:07419
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
Mileage: 166180km-103259mi Repair Order:
Coding: 0011773
VCID: 224BBD6DFDD30A2E48-8076
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 166167 km
Time Indication: 0
Date: 2016.03.13
Time: 17:51:58
Freeze Frame:
RPM: 1428 /min
Torque: 89.7 Nm
Speed: 55.5 km/h
Duty Cycle: 18.1 %
Voltage: 14.36 V
Temperature: 9.0°C
Temperature: 70.2°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 166172 km
Time Indication: 0
Date: 2016.03.13
Time: 17:57:44
Freeze Frame:
RPM: 1176 /min
Torque: 3.9 Nm
Speed: 48.4 km/h
Duty Cycle: 0.4 %
Voltage: 14.44 V
Bin. Bits: 00101011
Torque: 440.7 Nm
Coding: 0001001
VCID: 306F4725A33FA8BECE-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 40
Mileage: 166167 km
Time Indication: 0
Date: 2016.03.13
Time: 17:52:01
Freeze Frame:
RPM: 1472 /min
RPM: 1440 /min
RPM: 1280 /min
(no units): 36.0
(no units): 27.0
Temperature: 60.0°C
T.B. Angle: 17.6°
Coding: 0008557
2 Faults Found:
00003 - Control Module
014 - Defective
18265 - Load Signal
Component: ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 109
Mileage: 159808 km
Time Indication: 0
Date: 2016.01.19
Time: 05:06:26
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 0
Reset counter: 56
Time Indication: 0
Coding: 0015510
VCID: 285FAF459BEFE07E16-807C
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 37
Reset counter: 112
Mileage: 159955 km
Time Indication: 0
Date: 2016.01.20
Time: 05:02:27
Any thoughts on possible fixes? The light is still very intermittent, seems to be increased frequency in wet conditions.
Thanks again
Old 14th March 2016, 04:48 PM
Im still suspicious of the engine oil temp signal , just think that the engines running stratagy could limit torque because it thinks engine oil is to hot and plays it safe , gearbox and abs ecms see the signal and log codes to do with load signals.
Is the oil temp signal in the level sensor in the sump ?
Old 15th March 2016, 07:39 AM
It's coming up for service soon so i'll replace the level sensor at the same time as the oil is dropped.
In the meantime to rule out the earlier suggestion of MAF or TB faults is there any logging I can do to ensure they're running as expected?
Thanks
