I will clear all codes and take a drive so that you can see the reoccurring codes |
Sunday,13,March,2016,18:54:57:07419
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com Mileage: 166180km-103259mi Repair Order: ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGMª0070 Revision: --H01--- Serial number: AUX3Z0E9376803 Coding: 0011773 Shop #: WSC 00783 210 84012 VCID: 224BBD6DFDD30A2E48-8076 2 Faults Found: 000408 - Engine Oil Temp. Sensor (G8) P0198 - 000 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 8 Reset counter: 255 Mileage: 166167 km Time Indication: 0 Date: 2016.03.13 Time: 17:51:58 Freeze Frame: RPM: 1428 /min Torque: 89.7 Nm Speed: 55.5 km/h Duty Cycle: 18.1 % Voltage: 14.36 V Temperature: 9.0°C Temperature: 70.2°C 005715 - Please check DTC Memory of ABS Controller P1653 - 002 - - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 166172 km Time Indication: 0 Date: 2016.03.13 Time: 17:57:44 Freeze Frame: RPM: 1176 /min Torque: 3.9 Nm Speed: 48.4 km/h Duty Cycle: 0.4 % Voltage: 14.44 V Bin. Bits: 00101011 Torque: 440.7 Nm Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070556 Coding: 0001001 Shop #: WSC 02313 785 00200 VCID: 306F4725A33FA8BECE-8064 1 Fault Found: 009783 - Torque Management Feedback Signal A P2637 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 3 Reset counter: 40 Mileage: 166167 km Time Indication: 0 Date: 2016.03.13 Time: 17:52:01 Freeze Frame: RPM: 1472 /min RPM: 1440 /min RPM: 1280 /min (no units): 36.0 (no units): 27.0 Temperature: 60.0°C T.B. Angle: 17.6° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224BBD6DFDD30A2E48-8076 2 Faults Found: 00003 - Control Module 014 - Defective 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 14 Reset counter: 109 Mileage: 159808 km Time Indication: 0 Date: 2016.01.19 Time: 05:06:26 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 0 Reset counter: 56 Time Indication: 0 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FAF459BEFE07E16-807C 1 Fault Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 37 Reset counter: 112 Mileage: 159955 km Time Indication: 0 Date: 2016.01.20 Time: 05:02:27 ------------------------------------------------------------------------------- Any thoughts on possible fixes? The light is still very intermittent, seems to be increased frequency in wet conditions. Thanks again |
Im still suspicious of the engine oil temp signal , just think that the engines running stratagy could limit torque because it thinks engine oil is to hot and plays it safe , gearbox and abs ecms see the signal and log codes to do with load signals.
Is the oil temp signal in the level sensor in the sump ? |
In the meantime to rule out the earlier suggestion of MAF or TB faults is there any logging I can do to ensure they're running as expected? Thanks |
I have been having the same problem a week after buying the car from Audi so they took it back put new throttle body on as they said it was that still light coming on so then new maf still light coming on then they said they thought it was alternator not giving enough power to sensors so new one of them light went out for a couple of weeks then back on so this time I tried to sort it myself after a bit of digging around the web I found it could be brake light switch so have fitted one two weeks ago and it's now fine .6 pound switch from local spares and Audi under warranty spent well over 1500 in parts
