Thanks Psyche, I am speaking with Tozo already. He reckons its the clutch which is a 220 Euro part from Audi, but its inside the gearbox so it will need to come out for a rebuild... I was able to select reverse so yeah its probably the clutch. I will have to see what Ben thinks on Monday/Tuesday and will keep all updated.
Lets hope its a TCU, never heard of a TCU failing though? But I hear there a ten min job to swap over. Would the TCU show up on VAG COM? ![]()
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds Last edited by Singh; 21st March 2010 at 11:10 AM. |
Hope it's an easy fix Amar, but if not don't forgot the guys at Chester Autos, they know these boxes inside out
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
http://www.automatic-gearbox.co.uk/g...EF1BE5647B3929
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds |
I can just picture it now...
You rattling up the motorway in reverse to AVP ![]()
Well when I tested the reverse gear, the drive gear was working too. Its only after I started it again after I had parked it up for 15 or so mins it didn't go forward but then again it is a very steep drive, I didn't test reverse for the second time after it had been parked up. It may still work in Drive actually but when I heard the thud I got scared and turned it off.
I reckon if I disconnect the battery for a while that will take it out of limp mode, but limp mode is there for a reason I suppose. The cars 12 miles away so I can't go out and test again.
JT Automatics charge £290 labour to remove and refit a gearbox. Seems very cheap... How many hours is it to remove and refit a box?
IIRC Tozo has it down to about an hour each way
![]() Probably 2 hours each direction with some testing afterwards. Given the equipment you need to do it properly, that seems like a reasonable figure to me.
WOW!!
Clive... I assume you mean the whole refurb job rather than just a swap?
If you're on a ramp with a gearbox stand it's not actually that hard.
