http://www.automatic-gearbox.co.uk/g...EF1BE5647B3929
JT Automatics charge £290 labour to remove and refit a gearbox. Seems very cheap... How many hours is it to remove and refit a box?
IIRC Tozo has it down to about an hour each way
![]() Probably 2 hours each direction with some testing afterwards. Given the equipment you need to do it properly, that seems like a reasonable figure to me.
Sounds too good to be true, tbh, especially with a 24 month warranty.
I would have thought there's at least 40 hours labour involved alone.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
WOW!!
Clive... I assume you mean the whole refurb job rather than just a swap?
If you're on a ramp with a gearbox stand it's not actually that hard.
Yes, sorry.
Ben, if your reading this I will be giving you a call tomorrow, may need you to do a call out to Compton Verney. But Tozo seems confident its Clutch A thats gone wrong, guide for it is here http://www.audipages.com/Tech_Articl...vereplace.html
although I'm sure you don't need it, sooner its been checked over by Ben my mind well be put at rest. ![]()
I'm here mate.
If you have reverse drive but not forward then that's likely but a check is required. However, IF someone is offering a full rebuild with removal and refit for £1500 that's good!! Options are a: I come out and diagnose and we take it from there or b: we get it to me and if indeed the 'box is knackered I remove it and send it for re furb (either with my guys or to a repairer of your choice) |
