Old 21st March 2010, 04:35 PM
carrotchomper carrotchomper is offline
Default HELP! Urgent! Serious rear suspension problem
Help!
Drove to work, all was fine. Came out of work, and realised that the car was really, really bouncy on minor bumps. I've managed to nurse it the couple of miles home but it was extremely uncomfortable.
Both arms on the rear suspension seem to be completely "Jacked up" to their highest extent. I can't see any obvious oil leaks there.
I can't think of any particular impacts to have caused this. It went over the speed bumps in the work car park fine. I have had some turf in the boot recently which was heavy, but not excessively so.
What on earth has happened, and how do I fix it? The car is now completely undrivable. I didn't think A8s had ridiculous rear air suspension, I am now seriously worried how much this might cost.
Old 21st March 2010, 04:45 PM
It's a D2 isn't it? Shouldn't be air suspension. It's a problem that can occur on D3s where the system springs a leak or the compressor goes.
Seems strange that both sides have gone at once though. No obvious signs of a mechanical failure?
Some pics might help point us to an answer.
Old 21st March 2010, 04:54 PM
No obvious signs of mechanical failure at all, or indeed any odd noises beforehand. There really isn't much to see from the outside apart from the car being massively high on both sides!
Still, might be a chance to fit sport suspension... Although as you say, why have BOTH sides gone?
Edited to add- It's a 1998 D2 PF (Non-sport)
Old 21st March 2010, 05:23 PM
Just realised you said 'up' not down
That's a new one on me. Do the shocks look OK? Has one maybe failed (or lost the top mount) and the spring is pushing it up? Might also explain the bounciness if a shock (or both) isn't working.
Old 21st March 2010, 05:37 PM
TBH I am a complete nincompoop so don't know what they are meant to look like! Outwardly look OK though, but why both?!?!?
Old 21st March 2010, 08:12 PM
its a long shot, but self levelling (hydraulic) suspension was an option on the non-sport A8's.
If you had it, and it had developed some weird fault with the valve wedged open, it could explain the fact that both sides have been affected? Otherwise, the suspension on both sides is totally independent...
The build codes on your buidl sticker in the spare wheel well or service book would reveal what you have fitted....
Old 21st March 2010, 08:44 PM
Arse.
1BN = Suspension/shock absorption, automatic level control system
I suspect this is one option I didn't want to have. Is it possible to replace this with standard suspension or am I looking at an expensive trip to Audi- And moreover will this raise a fault code on Vagcom?
Old 21st March 2010, 09:42 PM
Makes a lot more sense now
Seeing as it's a PF D2 you've got, I'd imagine that it's a bit more of a brute-force independent system that's installed, though no doubt Ian will be along with a scary story in a bit.
Might be something you can release and re-set though.
Old 22nd March 2010, 11:50 AM
Looking at it today, it seems as if one of the suspension legs has "popped out" at the top of its travel. I'm hoping that the automatic levelling has reacted to this and therefore made the other side the same height... Just been recovered to the local Indy so I will see what they say. If it's expensive, then a new sportier suspension set up may be going on- Any recommendations?
Old 22nd March 2010, 07:03 PM
Wow.. the 2nd car ever that I've known to have it fitted... Yes, its that rare...
Interestingly, the oil filled shocks are usually the problem, and they sound like they might be working order so in all seriousness, hang on to them as they would be worth something to those that are seeking them....
As for replacing the sport springs, sure thing dead easy. The self levelling suspension is pressurised from the power steering pump and an extra hydraulic line runs the length of the car to the rear to a mechanical valve that opens/shuts in reaction to the suspension position relitive to level.
I guess this valve, or the linkage to it has gone astray.
It doesnt sound a big job to fix, but if you want to go for 'standard' setup then you just remove all the self leveling stuff and seal up the hydraulic feed, then pop standard shocks in its place... You'll want to change the springs too, and do the front ones if you want it all to sit at the rigth height for a 'sport' look... Very do-able....
any chance we can get a photo of the 'dragster look' before you fix it?
