Old 17th February 2016, 10:00 AM
Default ASR De-Activation Switch
Need a little D2 knowledge here...
Is this switch the type that when pressed is recessed in a little, then when pressed again is flush with the other buttons?
Also, when does the 'ASR' light up, when pressed in or when flush?
I have a little electrical project for swmbo's car.
Matt
Old 17th February 2016, 10:39 AM
I don't have one to test, but suspect being traction control related, it probably doesn't latch so that when you restart, it is back on by default.
The preface fog light switches were latching though as far as I know, so worst case buy one of them too and swap the faces.... ?
Old 17th February 2016, 11:03 AM
Thanks Ian
Yes that does make sense that the traction control wouldn't latch. I'll make do with an extra fog light button installed until the uber rare taxi button comes on ebay.
Just trying to solve a first world problem, oem style, to have an on off switch.
Matt
Old 17th February 2016, 11:53 AM
I bought a latching switch (from A8parts) for a "little project" as well, let me check what it was and I'll update this post in a minute......
Edit; More research needed, I just remembered that I swapped the cover to a different switch for cosmetic reasons - replacement cap is more appropriate to the functions it's for.
I'll get back to you.....
Old 17th February 2016, 12:00 PM
Pretty sure (from my purchase history from A8parts) that it was a hazard light switch.
£11.99: http://www.ebay.co.uk/itm/Audi-A8-D2...-/131140489767
I actually put the cap from a rear blind switch on it, the caps swap over easily enough, just clipped on.
The bulb inside the hazard switch I'm pretty sure has a separate circuit which I didn't need so it doesn't light up.
Old 17th February 2016, 12:07 PM
Oh that's great knowledge, thanks.
Swapping over the cap seems the way to go. Do you think the top half of the cap could be sanded down to opaque plastic, mask applied, re coloured black, then mask removed to reveal a new icon?
Matt
Old 17th February 2016, 12:45 PM
Can't comment on redecorating the cap as I've no experience of such things.
The illuminated ones have transparent/coloured sections in the plastic so it's not too thin.
Best to acquire one and have a look. I "invested" in two so that I could swap the caps.
Knowing me I'll have the spare bits, somewhere........................
Old 17th February 2016, 12:54 PM
Already put an order in, a rear fog switch, and I'll take a look when it arrives
Matt
Old 17th February 2016, 02:31 PM
Not sure the fog light switches are latching...... (I did research this carefully at the time but kept no records)
Old 17th February 2016, 02:38 PM
I was fairly certain they are.
When I did the PF to FL dash conversion in a PF D2, they were one of the biggest pains. The FL has a specific module that controls the fog lights, and it performs the latching function. The PF has no such module, the fog light switches effectively directly drive the fog lights.
So I had to fit the fog light module, as well as the full switch gear, and rewire....
