Old 24th February 2016, 04:36 PM
Catch up.... That was kind of its party trick Believed to be the only D2 sports model with individual rear seats in the UK...
Aye, it's a pity they're not red..
Old 25th February 2016, 02:13 PM
Talking
Because selling the RS6, buying an S5, and trying to work in-between isn't enough, here's this lunchtimes achievement.....
*had* to be today, I'm due a frost over the next few days to test...
Old 25th February 2016, 02:17 PM
That's some project, Ian!
Old 27th February 2016, 09:59 AM
Default Respect indeed
I'm in awe, as ever, at your combination of knowledge and attention to detail. The obvious question is….what are you going to do with her when you've finished restoring her to all her former glory? - or did I miss that at the start of this thread?
Old 27th February 2016, 05:56 PM
Form an orderly gentlemen!
Old 27th February 2016, 09:20 PM
Form an orderly (queue?) gentlemen!
Queue? Who?
Old 28th February 2016, 06:15 AM
Ah, yes, missed a word out!
Old 28th February 2016, 06:58 PM
Thanks....
I don't know. The 'plan' was to rescue her from any further 'improvements'. I had no exit strategy....
Much as I try, she's had a hard few years, and I'm not sure I could get it up to a standard that I would be willing to put my name to on resale, and its probably not worth letting go when it is in fact (with LPG) a bloody cheap V8 runabout with a luxury interior, sat nav, Bluetooth, etc etc....
If the RS6 goes, and I don't follow through with the S5, its not a bad way to have to get around for a while...
Old 28th February 2016, 07:29 PM
Not a bad Plan B really
Old 28th February 2016, 07:36 PM
And we have a heated screen refitted and setting nicely:
So, final hurdles of removing the previous heated screen retrofit. The black/yellow wire is the single connection that runs from the climate module to the rear of the car into the heated screen module. Here we find it, piggy backed onto a wire on pin 11, however it should have actually been on the unoccupied pin 11 in the connector highlighted on the right... So that was removed, and my new wire run in and connected. Interestingly, there is no coding to tell the climate module it has a heated screen, it just detects it....
Below I ran the negative connections to the bottom of the screen whilst the screen was out. I wasn't about to remove the whole dashboard for the sake of absolutely following the original wiring route, but bringing both connections up the drivers side, then its easy and very tidy to take the passenger side wire along the length of the dashboard between the dash and foam seal as arrowed.
The morning after installation, forecast to be below freezing, but sadly fell short and no frost. Attempted a test with ice cube, but its much thicker than frost, so was difficult to tell if it was eventually the heated screen that was causing it to melt, or the windscreen blowers as the coolant doesn't take that long with a V8 idling away.... Ho hum...
Note the power connectors for the screen quite visible still.
Onto a bit of refit: The old next to the new:
Final inspection before fitting revealed a few items to sort. Firstly, novelty though it is, the purist in me didn't find the need for a concealed set of flashing LED's behind the centre visor. Very tidy install by some previous owner on this donor headlining though
Secondly, a common oversight with headlining removal / installation is the correct and full population of the clips around the sunroof. If you cut corners here, best case you risk having a loose / ill fitting piece of trim within inches of your ear lugs. Worst case, its going to sag and hang down. So, I simply transplant across the clips so that the missing points (green) are populated with a clip (red)
so I have refitted the roof lining, and all the alcantara uppers. I've refrained at the moment from refitting any lower pillar plastics or the rear seats as they're in need of some serious cleansing before they get reinstalled....
ID:	12552   Click image for larger version
ID:	12553   Click image for larger version
ID:	12554   Click image for larger version
ID:	12555   Click image for larger version
ID:	12556   Click image for larger version
ID:	12557   Click image for larger version
