#191
![]() The usual: 01119 - Gear Recognition Signal 35-10 - - - Intermittent The expected: 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 35-00 - - I didn't clear it, though maybe I should?
#192
I cleared both codes and had a little potter back and forwards on the driveway, all fine and no codes returned.
Wait and see at this stage I guess, next trip is probably tomorrow afternoon/evening.
#193
F125 can come and go - moving it to R or D will make it likely to come on. If you start a journey and get to D without triggering the fault it won't come on at all until you next move the gear selector
Be warned there's 2 types of switch with different plugs so order from TPS with VIN to make sure you get the right one. Costs about £150 IIRC and bit of hassle to fit as box needs to be dropped a little to access I think, so one exhaust pipe off from memory If it's due a box service it makes sense to do at the same time as it'll save some labour
#194
Adrian, I'll probably get it all done by Guy sometime soon.
Had a few journeys since the "glitch", all totally fine. ![]()
#195
Mine does this once in a blue moon. If there is a pattern to it, it seems to be when I've reversed the car out of the garage to wash it and then driven it back in and left it. Next day it very occasionally goes into limp when I engage reverse again. Turning the ignition off and back on again always clears it.
I'll probably get it done at the the next gearbox service later this year.
#196
Mine used to do that when I first bought it years ago. Disconnected and cleaned the F125 switch connections; never done it since.
#197
Mark, was that just the wiring plug (8-pin I believe) or did you remove the unit from the gearbox?
#198
For an intermittent connection issue that appears unrelated to moving the gear selector, it'd be worth a try. If the symptoms seem to relate to movement of the gear selector it's more likely to be mechanical wear in the unit so no amount of cleaning the pins will help.
#199
The limp mode the other day is the only time ever that moving the gear selector has had any unexpected effect.
#200
The plastic undertray was missing when I bought the car, which I think probably left the connection a little more exposed than usual.
