Hi folks. Well I'm sat here totally at a loss as to how to trace which of these o2 sensors are goosed. Here's my VCDS log:-
Address 01: Engine Labels: 4D0-907-560-AVP.lbl Part No: 4D0 907 559 AA Component: 4.2L V8/5V G 0002 Coding: 10753 Shop #: WSC 02313 4 Faults Found: 16814 - Catalyst System; Bank 2: Efficiency Below Threshold P0430 - 35-00 - - 16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 35-00 - - 18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal P1639 - 35-10 - - - Intermittent 18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal P1639 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D56 Coding: 08397 Shop #: WSC 02313 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent Address 17: Instruments Labels: Part No: 4D0 919 035 BA Component: KOMBI+WEGFAHRS.VDO D39 Coding: 00483 Shop #: WSC 02313 No Faults Found or DTCs not supported by controller or a communication error occurred Address 56: Radio Labels: Redir Fail! Part No: 4D0 035 192 M Component: Radio BNO 0001 Coding: 00117 Shop #: WSC 00726 1 Fault Found: 00852 - Loudspeaker(s); Front 36-00 - Open Circuit I checked with the place that did my cats, they haven't sold or fitted 100cel cats for about 6 years due to MOT failures and too many customer complaints. So I'm confident the cats are 200cel. I'm about to delve into VCDS measuring blocks to see if I can suss out which sensors are giving out dodgy readings - anybody know what I should be looking for? I did a trial run earlier and had a look through all the different readings and blocks, so I've an idea where to look now, I just don't know HOW to look and WHAT to look for ![]() I've got Elsa on the go now so I'll report back if I find anything. |
