Old 12th March 2016, 12:27 PM
Derek29 Derek29 is offline
Default ACC not working
Just got my vcds system this morning, slowly getting use to everything, got the TPMS back on and working.
When I bought my car, the owner said the cruise control stopped working because someone made it so that you could watch TV while driving, and since then it doesn't work. Not sure if that's true or not, but ive got to sort it out now! When I go and pull the stalk (or any other direction) I just get " . . . " at the top of the display.
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041154
Shop #: WSC 00508 210 83382
VCID: 25419FF9ECDE3A162D-8070
4 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 53
Mileage: 159872 km
Time Indication: 0
Date: 2015.09.19
Time: 11:24:00
Freeze Frame:
Temperature: 31.0°C
Voltage: 11.01 V
Bin. Bits: 00000000
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 59
Reset counter: 93
Mileage: 160152 km
Time Indication: 0
Date: 2015.09.21
Time: 07:34:00
Freeze Frame:
Temperature: 10.0°C
Voltage: 8.32 V
Bin. Bits: 00000000
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110010
Fault Priority: 5
Fault Frequency: 34
Reset counter: 93
Mileage: 160152 km
Time Indication: 0
Date: 2015.09.21
Time: 07:35:00
Freeze Frame:
Temperature: 10.0°C
Voltage: 8.45 V
Bin. Bits: 00000000
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 13
Reset counter: 92
Mileage: 162648 km
Time Indication: 0
Date: 2015.11.29
Time: 13:02:00
Freeze Frame:
Temperature: 2.0°C
Voltage: 8.45 V
Bin. Bits: 00000000
Can someone confirm what the correct coding is for a 2005 w12? is "0041154" wrong? Or is the plot thicker than that...
Thanks
Old 12th March 2016, 01:42 PM
Have a look at my thread, you will find the coding info along with other stuff that may help you
http://forum.a8parts.co.uk/showthread.php?t=10419
Old 12th March 2016, 02:21 PM
Thanks, will go through what I have next time I'm in the car.
Old 19th March 2016, 12:54 PM
Success! The module was coded xxxxx4 instead of xxxxx5, someone removed the "add 1" for the rear seat entertainment.
Crazy to think one digit can screw up a £1500 option.
Old 19th March 2016, 02:48 PM
Glad you got it sorted, coding can be a fickle thing.
