right now I have your attention. lol. With the help of my great friend Marcin I managed to get a full fault codes before and after reset on my 8. Can you lovely folks break this down to me in Noob term so I can see what needs urgent attention and what I can leave for time being.Log-H-M3 1ST SCAN-WAUZZZ4E36N015057-189800km-117936mi 1.txt
Log-H-M3 AFTER CLEARING FAULTS-WAUZZZ4E36N015057-189800km-117936.txt hope this works....????? |
sorry if anyone would be kind enough to edit this so it can be viewed on the actual page?
ta |
Saturday,09,April,2016,14:34:37:36862
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com VIN: WAUZZZ4E36N015057 License Plate: H-M3 AFTER CLEARING FAULTS Mileage: 189800km-117936mi Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77 VIN: WAUZZZ4E36N015057 Mileage: 189800km-117936miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGM™0070 Revision: --H01--- Serial number: AUX3Z0E9377335 Coding: 0011773 Shop #: WSC 00618 210 91869 VCID: 224B051DFD400F2E48-8076 1 Fault Found: 005663 - Glowplug for Cylinder 6 (Q15) P161F - 001 - Open Circuit Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 188030 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:40 Freeze Frame: RPM: 630 /min Torque: 132.6 Nm Speed: 0.0 km/h Duty Cycle: 0.4 % Voltage: 13.83 V Duty Cycle: 24.9 % Temperature: 31.5∞C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 P HW: 09E 927 156 B Component: AG6 09E 4,2lTDI RdW 0030 Revision: --H01--- Serial number: 0070253 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 306FFF55A3ACADBECE-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0007557 Shop #: WSC 02313 000 00000 VCID: 224B051DFD400F2E48-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377335 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BF67F5EB9C95FE66-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 4 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 58 Mileage: 188000 km Time Indication: 0 Date: 2016.02.06 Time: 18:36:58 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 9 Reset counter: 80 Mileage: 188016 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:08 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 71 Mileage: 188352 km Time Indication: 0 Date: 2016.02.24 Time: 18:06:26 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 255 Mileage: 188544 km Time Indication: 0 Date: 2016.03.05 Time: 19:04:00 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063840 Shop #: WSC 02313 785 00200 VCID: 24470305E754011E3A-8070 1 Fault Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 2 Reset counter: 87 Mileage: 189344 km Time Indication: 0 Date: 2016.03.28 Time: 13:06:53 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 E HW: 4E0 035 729 A Component: Interfacebox H43 5150 Revision: 00000000 Serial number: 300KR057560990 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2E53E12DB998BB4EDC-807A Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000030612 Subsystem 3 - Serial number: 0106.02.070000000100010076ˇ Subsystem 4 - Serial number: 010076ˇ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000080247 Coding: 1136721 Shop #: WSC 02311 785 00200 VCID: 1C373BE5DF2439DE82-8048 2 Faults Found: 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 100 Mileage: 170922 km Time Indication: 0 Date: 2014.10.12 Time: 22:47:25 Freeze Frame: Voltage: 14.00 V 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 61 Mileage: 142775 km Time Indication: 0 Date: 2013.03.28 Time: 04:14:06 Freeze Frame: Voltage: 14.40 V ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H13 0210 Coding: 0143121 Shop #: WSC 02313 785 00200 VCID: 3169FA51A8A6A4B6C1-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 2 Faults Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 20 Reset counter: 70 Mileage: 186069 km Time Indication: 0 Date: 2015.10.21 Time: 19:55:15 00908 - Control Module for Wiper Motor 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 71 Mileage: 188665 km Time Indication: 0 Date: 2016.03.11 Time: 19:38:26 ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E1 910 409 A HW: 4E1 907 409 Component: 4.2L V8TDI G000AGS™0070 Revision: --H01--- Serial number: AUX3Z0E9377335 Coding: 0011773 Shop #: WSC 00618 210 91869 VCID: 224B051DFD400F2E48-8076 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H12 3610 Revision: 91H12360 Serial number: 0037P0009AY2 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 275D14099662EA061F-8072 Subsystem 1 - Serial number: 63328RB400C4BDE3Z Subsystem 2 - Serial number: 63428RB400C4BD1DX Subsystem 3 - Serial number: 63528RB400C4BE0F- Subsystem 4 - Serial number: 63628RB400C4BCED4 Subsystem 5 - Serial number: 63729RB400B6A080I Subsystem 6 - Serial number: 63829RB400BE574C. No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenks‰ulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02313 785 00200 VCID: 65C15E01ACEE3816ED-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000445 Coding: 0000413 Shop #: WSC 12345 001 136936 VCID: 3169FA51A8A6A4B6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 P HW: 4E0 920 950 P Component: KOMBIINSTR. VDO H71 0400 Revision: D02 Serial number: AUDID3EN000445 Coding: 0000413 Shop #: WSC 12345 001 136936 VCID: 3169FA51A8A6A4B6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0110 Revision: 0000000C Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3B3DFDD51047EE90-804E 2 Faults Found: 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 2000305B098159 Coding: FCFEFFDE2B7504 Shop #: WSC 02313 785 00200 VCID: 275D14099662EA061F-8072 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE8014054 Shop #: WSC 00000 000 00000 VCID: 1C373BE5DF2439DE82-8048 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H08 0160 Revision: 01604808 Serial number: AUX3Z0E9377335 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BF67F5EB9C95FE66-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 4 Faults Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 58 Mileage: 188000 km Time Indication: 0 Date: 2016.02.06 Time: 18:36:58 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 9 Reset counter: 80 Mileage: 188016 km Time Indication: 0 Date: 2016.02.07 Time: 14:48:08 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 8 Reset counter: 71 Mileage: 188352 km Time Indication: 0 Date: 2016.02.24 Time: 18:06:26 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 255 Mileage: 188544 km Time Indication: 0 Date: 2016.03.05 Time: 19:04:00 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 015 0220 Revision: 00000018 Serial number: 00000000034090 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C94A11B8C6543611-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 00613 210 88222 VCID: 2A5BED3D8570D76E00-807E 2 Faults Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 100 Mileage: 188446 km Time Indication: 0 Date: 2016.03.01 Time: 20:11:47 01398 - Signal Conductor for Central Locking; Doors Open 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 5 Reset counter: 82 Mileage: 188692 km Time Indication: 0 Date: 2016.03.13 Time: 23:12:31 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063850 Shop #: WSC 02313 785 00200 VCID: 24470305E754011E3A-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 D Component: MNS ECE H46 1060 Revision: 00000000 Serial number: 364K/057506849 Shop #: WSC 02313 785 00200 VCID: 3B75D8797AEA5EE66B-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000528500018 Coding: 0035984 Shop #: WSC 02313 785 00200 VCID: 1D3136E1C43E30D675-8048 1 Fault Found: 00207 - Humidity Sensor Heater (N340) 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 0 Fault Frequency: 15 Reset counter: 102 Mileage: 187972 km Time Indication: 0 Date: 2016.02.06 Time: 17:52:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: T¸rsteuer.FS BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204F0F15F34C1D3E5E-8074 1 Fault Found: 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 98 Mileage: 189696 km Time Indication: 0 Date: 2016.04.05 Time: 13:35:48 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040511080555 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 285F17359B7CE57E16-807C Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0060 Subsystem 2 - Component: NGS keine Antwort 2 Faults Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 23 Reset counter: 87 Mileage: 188030 km Time Indication: 0 Date: 2016.02.07 Time: 17:14:50 02167 - Control Module for Tilt-Sensing Alarm (J529) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 254 Reset counter: 62 Mileage: 153604 km Time Indication: 0 Date: 2013.12.19 Time: 21:10:44 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H02 0120 Revision: PROD_01 Serial number: 00000000200618 Coding: 0000021 Shop #: WSC 02313 785 00200 VCID: 2C57EB258F84C95EF2-8078 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000073177 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: T¸rsteuer.BF BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 204F0F15F34C1D3E5E-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0001031 Shop #: WSC 00654 210 60455 VCID: 1F4D0CE9CE3222C667-804A 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 239 Mileage: 187928 km Time Indication: 0 Date: 2016.02.04 Time: 16:05:13 Freeze Frame: Voltage: 12.53 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000006 Shop #: WSC 02313 785 00200 VCID: 3D71D66164FE50D655-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 Q HW: 4E0 035 541 L Component: TUNER EU/US/RDW H42 0620 Revision: 00000000 Serial number: 304KK057611415 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2E53E12DB998BB4EDC-807A 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 6 Reset counter: 102 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 C Component: TV analog TUNER H14 0300 Revision: 00000072 Serial number: 00000000021917 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 25411E01EC6EF8162D-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000005041 Shop #: WSC 00947 210 62103 VCID: 204F0F15F34C1D3E5E-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1511070713 Coding: 344530393135313035412056413031353131303730373133 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: T¸rsteuer.HL BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000511090356 Shop #: WSC 12336 024 394758 VCID: 3663C94D41C8838E94-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: T¸rsteuer.HR BRM003 0100 Coding: 0032622 Shop #: WSC 02311 785 00200 VCID: 1E3331EDC9382BCE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720528502256 Coding: 0201108 Shop #: WSC 02313 785 00200 VCID: 23450019E25A062643-8076 1 Fault Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 63 Mileage: 187972 km Time Indication: 0 Date: 2016.02.06 Time: 17:50:58 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 C Component: TELEFONMODUL EU 0770 Revision: 00000007 Serial number: T2AUDX0706J1VP Coding: 0000005 Shop #: WSC 02313 785 00200 VCID: 224B051DFD400F2E48-8076 No fault code found. End-------------------------(Elapsed Time: 03:35)--------------------------
. Nite Blue 3.0L SE Quattro |
Delete all the codes now you have a copy saved and see what comes back, a couple of codes are dated 2013 so it hasn't been read and cleared in a while.
Something happened on the 6th Feb this year as quite a few codes are dated then, I wouldn't worry to much yet till they have been cleared and you drive it round for a week or two and see what comes back ![]()
I bet most of the codes will clear and not come back. Maybe the ignition was on with battery off, unplugged a module with battery connected etc.
cheers guys but I have only had the car for few months so don't know past diagnostic history. I am sure marcin did reset it as the logs are prior and after?
Very strange
![]() Marcin knows his way around A8s but the second log is identical to the first [except time of run and odd bug where ECU 17 repeats in second log]. I've never seen a VCDS 'DTC Clear' where none of the DTCs seems to have been cleared. Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
sometimes using the remove all dtc's doesnt get rid of them all, ussually some though. you then need to go in to each module in turn and delete them and see if they come back
+1 on what he said ^^^^ Often the case!
