Due to time and other work comitments it's not finished but the 'box is back and in the car!
![]() I will be interested when I come to test it - they got the box back to me after only 1 full day!!!!!!! Only unfortunate thing in my opinion is the crappy silver spray paint all overhaul companies insist on using. Looks tacky!! They have definately had the whole thing in bits though as the sealant on main drive section, torsen diff and front final drive was still wet when I got the box back!! Will probably end up working Monday aswell and finishing this so will update when complete |
Ben, can't wait to see pictures of the box. Don't be afraid to give it some welly when testing it
![]() Will I be collecting on Tuesday then? Its just that I need the tracking and wheel balancing done and I'm guessing that place wouldn't be open on Monday?
Hi there,
I really hope this rebuild is as good as we all hope it is. I say this from a selfish perspective ‘cos if it works out this may well still be the most cost effective solution for my gearbox too so I’m very interested in the outcome. Question about the rebuild - do you know if they also replace/ recondition the solenoids/ pressure valves in the valve chest (i think that is the name of it anyway) i.e. the brain of the gearbox? or is the rebuild limited to the mechanical parts within the gearbox itself? Thanks Niall
Gone, but not forgotten... 2000 A8 4.2 Quattro – Green, S8 18’s, Xenons, PhatBox, and loads of other toys. |
Hi Niall, all I know for sure is they replaced the clutch with a better heavy duty Kevlar one and rebuilt the torque converter. They did a full strip down of the box and inspected all the components. Nigel knowing I was willing to splash out extra money told me that it didn't need anything else, which I applaud him for. The service from him has been very good, answering all my questions, returns calls straight away and constantly keeps you updated of progress. Free collection of the gearbox/car and a free service and check over after 1k miles. I'm going to have my gearbox serviced every 10k miles now/every year.
Thanks Amar for the quick response.
So it is probable that your valves were in good order and did not need to be replaced. I just don't know about my gearbox so. I don't have any obvious mechanical crashing etc, well apart from the severe thumping and hopping from gear to gear lower down the range. i've had all the electrical connections etc checked and they are all good. So i'm wondering if what Amar has had done would be sufficient for my situation at all as i "think" it is to do with wear off the valves or damaged valves. Ben, you're prob most familiar with my situation - what do you think? Or if anyone else has thoughts on this i'd welcome the input. Niall
Niall, get that AA breakdown repair cover warranty now, that £475 may come in handy
![]() VMT will give your car a free check over and can probably diagnose it there. If you speak to a guy called Tozo on quattroworld forums he can defiantly advise you on what your problem is.
