Old 4th January 2016, 06:35 AM
Borys's Avatar
Borys Borys is offline
Default Adaptive light defective
Is there any way to disable this function?
I have an intermittent fault and the beep is getting on my dark side
Sometimes it will not come on for a month.
I belive it is connected to ride hight sensor so we can never be sure if it is the light or suspension hight.
Fault comes up as left light sensor (would it be a good practice to check all relays first as they are known to have dodgy connections, specially now when its wet?)
Or Is it possible to program it as bixenons without adaptive function?
I manage to get rid of tpms annoying beep from the dash hoping it can be done with lights
What do you guys think?
Old 16th January 2016, 03:53 PM
Borys's Avatar
Problem solved
It was a badly corroded conector on front suspension sensor
Cleaned nicely and fault is gone
For future reference - first thing to check, sensors - do not fall for new headlight needed
Old 17th March 2016, 01:36 PM
kele kele is offline
Ah, maybe the same on mine? I will check...
I had the adaptive NS headlight permanently pointing to the pavement. Also ,the corner assist NS lighting coming on at random (at all speeds).
Got the following codes:
Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0040 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: E9DF4BFFC0FBB056AC3-80BC
4 Faults Found:
02627 - Dynamic Cornering Light Motor; Left (V318) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 153 Mileage: 229915 km Time Indication: 0 Date: 2016.03.07 Time: 18:01:12
02627 - Dynamic Cornering Light Motor; Left (V318) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 153 Mileage: 229921 km Time Indication: 0 Date: 2016.03.07 Time: 19:16:43
02235 - Stationary Cornering Lamp (Left) (M51)
007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 2 Fault Frequency: 6 Reset counter: 200 Mileage: 229941 km Time Indication: 0 Date: 2016.03.09 Time: 18:23:17
Originally Posted by Borys View Post
Attachment 12346
Problem solved
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 17th April 2016, 09:55 AM
Only just got around to this job.. I'm struggling to locate the connector. It does not appear to be in the same place as the pic from Borys on mine. I will have to check the tech guides.
Old 17th April 2016, 07:55 PM
Lee S Lee S is offline
It's the connector at the end of the loom right in the middle of your photo, that goes to the level sensor.... just from a different angle and with the splash guard still on.
Lee
2017 Nissan Leaf Tekna
Old 17th April 2016, 08:24 PM
Thanks. I pulled that and all was good in there. So the issue must be something else...
Old 3rd October 2016, 10:42 AM
So I have spent the last few months looking out for a N/S headlight (4E09410064BF) but to no avail. And I checked with our sponsors (obviously)..
So my idea now is to simply buy a matching pair. Different part numbers. Is it just a case of changing the adaption to suit the different part numbered headlights? If so, how would I go about finding out what adaption to use? And I assume that the pre and post FL units will fit as long as it is coming from a D3 with a single grill 2005>
I want to have a replacement to hand when I take the faulty unit out. Albeit that it may in fact prove possible to repair the faulty unit when I get in there. I can then always resell the units if I don't end up fitting them.
With winter approaching now, I need to get it sorted... plus this is the only fault with the car on VCDS and it 'nags' me.
