Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 30th May 2016, 12:55 PM
nath nath is offline
think i have it sorted now guys
it does look as if the fault was the black sensor (i ordered mine from tps for about 90 quid inc vat )
the sensor isnt that difficult to replace but you do require a 27mm DEEP socket
you wont get it out otherwise
the faffing bit was the programming
luckilly i had help from a guy from denmark over on the vcds forums
uwe at ross-tech suggested i went into basic settings and did an adaptation which codes the sensors with standard information
you then have to reset the codes and get rid of any fault codes
the only fault code that should then show is one referrng to the sensor not having been tested
go into the security section and enter the security password
the look for an option to "pressure test"
once this is done everything should be fine
thanks again to all those that helped sort the problem
