Old 8th June 2016, 09:04 PM
Both my front one have packed up - again - seems terminal.
The passenger still 'clicks' but the driver's side feels hard or already down.
If anyone even replaces there, it would be good if you could cut the old one's button out and see how it works as it might allow us to figure out a repair or maintenance.
Old 9th June 2016, 03:23 AM
H-M3 H-M3 is offline
ill keep an eye on this thread as my rear pass does not work
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 9th June 2016, 08:47 AM
Didn't somebody post they got some extra life out of their keyless locking button by soaking it with wd40 ?
I can't find the post, but it rings a bell....
Old 9th June 2016, 08:57 AM
Norretal's Avatar
Norretal Norretal is offline
I definitely read that too, tried it but it didn't work for me. My fronts don't work but the rears do, it's no hassle to press the key fob though
Audi TT - 2015 - Ultra
Old 9th June 2016, 12:53 PM
I sprayed mine with contact cleaner in the gap with the aerosol straw while using loads of kitchen roll to keep it off the paint, then used silicone spray to make it water repellent.
I have got the passenger one working 3 times over the years but not any more.
I will try the driver's button, but seems to be a different problem, the button feels duff.
Old 9th June 2016, 06:07 PM
Turbo Tony's Avatar
I've only got one that works on my car. Two worked when I bought the car, but the driver's one has gone now. You can hear water squelching in it.
A new door handle is around £105 from Audi, plus spraying and fitting.
Storytellers Villa Orlando
2008 Audi S8
Old 10th June 2016, 06:40 AM
mannyo mannyo is offline
I must be lucky in that all 4 of mine are still working, but the passenger rear is a bit squidgy when pressed. I do however have intermittent issues with the touch sensors based on the weather.
Manny
Past
