Old 9th June 2016, 06:25 PM
Nikkei92 Nikkei92 is offline
Default Another Parking Brake Malfunction
Hello,
I have another Parking Brake Malfunction. Same code as snapdragon had at the beginning.
Code:
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000331
   Shop #: WSC 00656 210 88563
   VCID: 1D3B9B93C43580D675-8048
1 Fault Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            012 - Electrical Fault in Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11111100
                    Fault Priority: 1
                    Fault Frequency: 16
                    Reset counter: 103
                    Mileage: 233128 km
                    Time Indication: 0
                    Date: 2003.03.05
                    Time: 07:00:35
- Both 30A fuses near by battery are OK.
- I bought a new motor to the left side but that didn't help at all. Also tried to install motors to the different sides but still problem stays at the left side. Just wanted to make sure a new motor is not broken already.
- I measured with a multimeter a whole wire from motor to control unit and its OK.
- I bought an used control unit with part number SW 4E0 910 801 D and installed it today but still, same fault code.
I have not changed a caliper, but it doesn't make sense to me how it would make any difference in this case, when fault code says "Electrical Fault in Circuit"?
Does anyone have any idea how to test further?
Is there any tricks what i should try with VCDS?
I haven't found any relays or fuses to the EPB except those two 30A in luggage?
Thanks.
