Old 19th June 2016, 08:12 AM
Storka's Avatar
Storka Storka is offline
When you've swapped the abs module you will always get that error unless you got a brand new one and had it fitted by Audi - at least that's what I'm led to believe
A couple of years ago.
I bought a used abs and got same error as the original.
Thought this one has the same problem.
Sent the new used one away to get reconditioned in the states.
Installed it when it came back.
Guess what "........same error code.
So live with it unless you want to try a new abs.
Also heard it's doing the brake testing routine with the vag com that does it.
I know I did it before I noticed the error code
