Old 22nd June 2016, 02:54 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I'll have to take something first to build up Dutch courage
My luck is that it will break something else
You're lucky to have it 5 times already. That's the way I see it!
2007 Mini Cooper S R56
Old 28th August 2018, 03:50 PM
ulfilias ulfilias is offline
Hi There,
Did anyone find a solution ???
I've got this too....Brakes work fine and always have done. The ESP button I don't think works though I've never really seen the need to use it (I did change the button at one point but that made no difference).
I'm not too bothered but recently i've got a big ! and the logo lit up when driving.....seems to last about 30 seconds then go away. Appears to be under acceleration rather than braking but haven't yet found an error.....Did 300 miles at the weekend with it only once and then today on 12 mile commute it came up!
Lee
Current :
Previous :
Also :
Old 28th August 2018, 04:45 PM
Originally Posted by ulfilias View Post
Hi There,
Lee
Low brake fluid? As you accelerate fluid shifts backwards, level at the float drops and light comes on.
Old 29th August 2018, 07:25 AM
Hi There,
Could be. I went to check but found my stash was out. Bottle of fluid due today!
I'm still curious about resetting the module though as it seems to be working and doing all the important stuff, just some form of bit not set causing the error in VCDS and then not logging errors properly!
Lee
Current :
Previous :
Also :
Old 5th September 2018, 02:43 PM
Well....Whilst it didn't take much in the way of brake fluid, I've not had the flash occur since, so I think it was fluid!
I've just had a bit of a play with the ABS with VCDS and an old version of VCP (5 or 6) - I tried logging in, resetting and recoding all with reasonable success.
However i've not been able to clear the fault. I think it is some sort of bit set in software rather than an actual fault with it. I hoped adaption / coding would sort it but NOPE.
I'm guessing a software flash probably would, but I can't seem to find how or where to do this apart from specialist shops / Audi
It's an irritation, but i'll live!
Lee
Current :
Previous :
Also :
Old 5th September 2018, 03:40 PM
Hi Lee,
The ABS, ESP 5.7 in the D3, isn't flashable.
Matt
Old 5th September 2018, 05:26 PM
Hi Lee,
Really.....Could have sworn i'd read about the dealers updating the software on it ??? Am guessing that it's beyond the normal software and into VAS5054 / ODIS etc
Current :
Previous :
Also :
