Old 8th July 2016, 10:16 PM
47p2's Avatar
47p2 47p2 is offline
If it were the MAF it would still run, but would faulter under load and possibly throw a fault, so I don't think the MAF is your problem. (I could be wrong) Sounds like a petrol problem, either not enough in the tank or a faulty pump. I would stick another 5 litres in and see if there's any difference
Nite Blue 3.0L SE Quattro
Old 9th July 2016, 07:21 AM
Will try that too John. I guess it's a matter of trying out each potential cause.
Old 9th July 2016, 09:17 AM
OK, got a VCDS scan.
In 01 Engine address it states:
17978 Engine start blocked by immobiliser P1570-35-00
18058 Powertrain data bus P1650-35-00 Missing message from instrument cluster
also 03 ABS:
01203 Electrical connection between ABS and Instrument cluster 31-00 open or short to ground.
I noticed that the VCDS didnt pick up the VIN code. I have also realised that the odometer isnt showing when the ignition is on and this along with the fact that fuel gauge (as mentioned before) is on the stops and not registering anything suggests that there is an issue with the instrument cluster . Or is the above a result of a the immobiliser doing its thing? I notice that someone else on here posted about the immobiliser wire this morning - is this the season for it? Any further help/suggestions on way ahead much appreciated.
Old 9th July 2016, 09:45 AM
Hmmm. Sounds like it could be a missing instrument cluster power feed.
After a quick look here (page 8) ...
http://forum.a8parts.co.uk/attachmen...8&d=1420349196
... I'd probably be checking S1 (ST4) first.
Old 9th July 2016, 09:48 AM
Thanks Mark. will check that out.
Old 9th July 2016, 09:52 AM
first question is where is the S1/ST4 fuse carrier ?
Old 9th July 2016, 10:03 AM
OK think i have it (RTFM!!) page 1 shows that!
Page 1 shows the carrier.
Not 100% sure without checking but I would guess driver's footwell. Looks like row 4 (ST4) fuse 1(S1).
Failing that, I'd just check them all!
EDIT: haha, replied at the same time!
Old 9th July 2016, 11:01 AM
Well its not Fuse S1/ST4.
Now starting to grasp at straws..... the Starter Inhibitor Relay (J207 - in the passenger footwell) is controlled by F125 switch so would a fault there give the symptoms I have or would it not allow the engine to turnover/fire at all? But there again I seem to have lost power to some elements of the instrument cluster as I stated earlier which points towards a power supply issue to the cluster.....
Old 9th July 2016, 11:22 AM
I would say the lack of power and communications to the instrument cluster has to be the clue. There may be another fuse involved. Might be easiest to just visually check them all.
