Good luck, I'm sure you'll be fine.
2006 D3 A8 4.2 TDI. SPORT. Nite Blue. |
Good luck chap!
Mine failed the MOT This year, 10 years old so 7th MOT. It was tyres. Grrrr! They were just legal when I booked it but worn on the edges due to replacing tie rods and tracking by feel. Sadly one showed a sliver of canvas on the day and it failed and quite rightly. I was going to do the tyres after the MOT but wanted to make sure nothing more expensive showed up first. I had the 4 wheel alignment done here and was impressed... http://www.kandmautocentre.co.uk/wheel-alignment.php because they used a Hunter Elite which was the best I have seen. It plugs in the ODB port and does the ride height and steering angle to 0.00˚ before they start, the bits that fit on the wheels are plastic and don't touch (mark) the rims, they hang on the faces of the wheels and the car rolls back and forward and any off centre run-out is accounted for automatically. It can also do the S curve (tow constant) that our cars have, but to be honest I think they skipped past it. It had instructions on the screen to lift and lower the car and check the tow is constant and showed them to undo the screw on the balljoint and move it up or down. ![]() |
