Old 27th April 2010, 11:54 AM
The yellow (O) is one of the few errors where Vagcom is of no help whatsoever....
Its nothing to do with ABS either, its just your brake pad warning.
This is a simple single loop of wire that runs through both front pads and back to the cluster. Break the loop, the warning comes on....
More than likely you just disturbed it when working at the front end, There are 2 wires connected to the front pads. Sort this out, the light will go out...
