Old 5th August 2016, 01:06 PM
it seems a new headlamp is required at £889.
You do realise you'll now have one shiny new headlight and one duller old one. You need someone to reverse into the other side now.
Old 5th August 2016, 06:29 PM
pete-p's Avatar
pete-p pete-p is offline
That's a good point let's hope it won't stand out too much. I think I'm a little more concerned that the chrome strips on the front bumper will be nice and shiny when all the others are a little milky.
Cars...
Old 5th August 2016, 08:57 PM
Turbo Tony's Avatar
Don't worry, you can polish the existing light and it'll get close to the newer one.
Fingers crossed for you, buddy.
Storytellers Villa Orlando
2008 Audi S8
Old 7th August 2016, 09:37 AM
The outer lens can be replaced without buying a whole new unit, but they're a funny design anyway so I don't expect any difference to be noticeable.
Old 10th August 2016, 02:24 PM
pete-p's Avatar
This is taking a while to sort...
Apparently it's borderline uneconomical to repair. They are going to send an engineer out to asses my car, maybe he'll just do a desktop assessment. Possibly the good thing is that there are only a couple for sale and at decent prices (including a LHD one at £15k!). Maybe this will help on a valuation I don't know, I guess it depends on the engineer knowing the difference between an A8 and an S8.
I'm going to stand my ground that it's repaired as the D2 S8 is a fairly rare car and hard to replace. I've also asked the garage if the headlamp is damaged or could be used, since this is adding a lot to the estimate. They've said that the bracket is broken but could be bonded if this reduces the estimate enough.
Time will tell... In the meantime I still have the D4 hire car.
Cars...
Old 10th August 2016, 07:45 PM
Th D4 hire car will be costing them more than the headlight and probably the full repair
Old 10th August 2016, 08:07 PM
Is it one of the top tabs which screws to the slam panel? You can get repair kits for those for about £20 - 4D0998121A. They screw to the housing in place of the broken tab.
Old 10th August 2016, 08:55 PM
pete-p's Avatar
I know, you'd think they would worry about that more than the cost to repair the car.
I'm not sure it's the tab, it looks more like the housing. I can't see for myself yet as too far away, but here is the photo from the estimate.
Cars...
Old 10th August 2016, 09:21 PM
There doesn't look to be anything wrong there
Old 11th August 2016, 07:36 AM
pete-p's Avatar
If you look carefully he is pointing to a small crack. I didn't notice it the first time. It seems a waste to replace the whole unit just because of that.
Cars...
