Old 8th August 2016, 08:47 AM
Default D2 Lower Control Arms
Had an advisory on the MoT in January about the front lower control arms bushes starting to deteriorate. (The upper arms were replaced with Lemforder ones in Dec 2012.) Just recently have noticed juddering when braking which was a cause(amongst other things) of similar shudderingwhen the upper arms were worn. Does anyone have a pair of lower arms lying around that they want to sell?
Old 8th August 2016, 10:02 AM
The lower arms are the same as loads of other models and so relatively cheap for aftermarket replacements. I use Meyle HD since they come with a 4 year warranty and are pretty well priced - £110 for a pair of front lowers. Very nice quality, and they come with new hardware too. The Meyle number is 116 050 0031/HD
http://www.ebay.co.uk/itm/Pair-MEYLE...MAAOSwB4NWvKxg
Old 8th August 2016, 10:58 AM
Thanks for the info Mikki, Just thought I would ask on here as someone did have some control arms for sale a short while back.
Old 8th August 2016, 12:53 PM
it was this link here I think David -
http://forum.a8parts.co.uk/showthread.php?t=11022
Old 8th August 2016, 03:24 PM
Ah thanks Neil.
1 digit difference in the part number and Mugzee has a A8 ... mmm Need to do some research.
Old 8th August 2016, 09:42 PM
Those are for the steel hubs - the pin on the end is larger, so they won't fit an FL car with alloy hubs.
They're more expensive than new correct ones on ebay anyway
Old 8th August 2016, 10:33 PM
RICKY D's Avatar
RICKY D RICKY D is offline
I bought a complete Meyle HD set from Germany for £350.
My car thread
http://forum.a8parts.co.uk/showthrea...t=11855&page=3
EBay ad
http://m.ebay.co.uk/itm/MEYLE-HD-SUS...%257Ciid%253A8
I know you only need two arms but maybe use the saving for the entire kit for the future?
Old 9th August 2016, 07:07 AM
I bought a set of those some time back and, despite assurances, 2 of the arms were the wrong ones and had to be returned for a refund.
Old 9th August 2016, 08:13 AM
The Meyle ones on Ebay specifically state that are not for 20" wheels so they are OK for me.
Thanks Ricky for the info and it would be a sensible precaution but I will rely on the fact that the Lemforder uppers I fitted a while back holdout for me!
MikkiJayne: You are right, Mugzee's are for steel hubs - the 1 digit difference I think confirms that and I have been in touch with Mugzee so it looks like the Meyle ones are the way ahead.
Old 9th August 2016, 08:35 AM
Ricky's link is also for steel hubs if the picture is correct (larger pins on the front arms).
There are two types of lower front arms on most Audis - large pin on B5 and C5 / D2 with steel hubs, small pin on B6 and C5 / D2 with alloy hubs. There is a 3rd type which is unique to the 20" D2. Almost all the D2 Meyle kits I found on ebay were the large pin versions, but in fact its exactly the same price to buy all the arms separately as it is to buy a kit so simple enough to just change what's needed
