SAI solenoid valve - it sits on top of the fuel rail in that corner. You can just see it next to the breather hose in my second pic, with two vac lines connected to it. The vac input goes to the front where the manifold valves are, the vac output goes down the back to the kombi valves.
![]() The red arrow points at the valve. The green line is the vac supply from the front - this is tee'd in to the main vac line to the reservoirs in the wings. The yellow line is the feed to the kombi valves, tee-d underneath the round oil separator pod. ![]() Last edited by MikkiJayne; 27th August 2016 at 07:30 AM. |
Wondered where the 2 long vac hoses went to.
Valve missing from the box of misc. bits that came with the car. New one ordered from tps this morning Thank you for the info ![]()
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
