I have the same problems as you guys. 2 screws broken and stuck in there.
I had an identical problem with broken off head of the license plate screw. So i drilled out the nut that is pressed on to the body and bought some rubber nuts and installed those instead. ![]() Now, if the screws get stuck again i can just drill of the head, remove the whole rubber nut and replace with a new one with no problem. Im thinking of doing this to the glass from the license plate light. Just drill out a bigger hole for the rubber nut and install with new screw ![]() PS! Its a little more work but sounds easy though. |
Good idea, I actually think I have some of those lying around, you usually buy them as a matching bolt/fixing pair.
Same sort of idea as I referred to above:
Generally known as rubber nuts or well nuts.
You obviously have to choose the correct type for the combined thickness of the fixing/fitting/backing and screw thread.
Yeah.. Did some googling and found a rubber nut that was 10mm thick so that should work.. M2 screw but the head is quite big so going to see if i can find some other screws with smaller head.
I have now used these to secure my license plate on the tail gate and my ECU as both of the chassie screws where broken off some how ![]() ![]() Now they are secured pretty damm good ![]() |
A common issue, the number plate light lens screws got firmly wedged and couldn't be removed. Needed to drill them out and I replaced the handle unit. However, the one that i bought wasn't for a model with a reversing camera...so off again to the dealer for another one, and to be sprayed also...
So, i have a spare boot lid handle (for non-camera) for sale if anybody is interested....!!! |
