Old 1st September 2016, 02:36 PM
Pads rattling in the carriers? Ie worn carrier rather than anything peculiar to the pads themselves.
Old 1st September 2016, 08:30 PM
vagdream vagdream is offline
Had a similar noise on FL D2 S8 when the cats started breaking up internally.
Old 2nd September 2016, 08:21 AM
Had that too. Open the door, stick your head out and rev the engine. Rattling cats should be obvious if that's the problem
Old 2nd September 2016, 08:32 AM
Very obvious indeed. I bought my current S8 with a rattling cat. Though by the time I finally got round to replacing it the rattle actually stopped - nothing left inside!
Old 2nd September 2016, 10:55 PM
a42l2011's Avatar
a42l2011 a42l2011 is offline
Not rattling cats.
On brake carriers there was some indentations where the pads rest so I kissed them with grinder to smooth them out. the springs on top of the rear pads keep them pressed tight. This moves pad toward center a fraction. I also switches carriers left right because one of the guide pins are usually slightly sloppier than the other because of the direction of rotation.. I have done this same treatment to all my Audis and friends cars also. Great success with no down side on any other cars. Probably 20+ cars in 10 or 12 years. In fact more even pad wear. Had rattle before and after carrier swap/treatment
I When I stripped the entire trunk of everything and even removed rear bumper. I rode in the back seat leaning out the window. The sound appeared to come from the right rear wheel well (although I didn't actually lean out the drivers side...hmmm bet it sounds horrible on that side also).
I am down to the rubber surround on the center driveshaft. It is probably deteriorated to the point that it allows contact. Funny that I have some vibrations on highway but nothing major. I also live in area that I seldom drive faster than 50-55. Mostly country roads without long stretches of smooth pavement. I always blamed vibrations on low profile tires and road surfaces. I think the sound must echo down the tunnel created by heat shielding. My street is the acid test of vibrations. When I have the windows down and hit bumps people turn and look. Sounds like a garbage truck.
I'll be doing exploratory disassembly when I get the rear transmission output seals and get some picks when I find root cause.
thanks for all suggestions.
Old 3rd September 2016, 07:30 AM
Something that might help locate/eliminate sources: Attach a cheap GoPro type camera underneath, pointing at anything you suspect might be the cause.
Old 3rd September 2016, 12:04 PM
You need to get it on one of those 4 post road simulator shaking lifts, not sure if or where are they available in UK but some countries use them for MOT equivalent tests, I think one of them is Germany.
