Old 6th May 2010, 03:04 PM
CliveH's Avatar
CliveH CliveH is offline
Default What next?
what the heck is next?
manual gearbox conversion and rear euro sports seats...?
Old 6th May 2010, 03:15 PM
You forgot Xenon Plus's
Thanks Ian, I will nick it out of my sisters MK4 Golf when she gets home from work this evening, hopefully its the same. Can someone get a pic of it installed. I couldn't see it. Was looking above the CD changer, my car doesn't have one of them gay aerials
Old 6th May 2010, 03:18 PM
You have to remove the side trims behind the Cd changer ??
Old 6th May 2010, 03:25 PM
Of course, *goes out to check*
Old 6th May 2010, 03:38 PM
This is all I could find and it looks nothing like what Ian posted.
Old 6th May 2010, 03:44 PM
That would be the central locking pump... Look up higher into the very top of the wing.....
Old 6th May 2010, 03:56 PM
Found it now, spot on Ian.
Old 6th May 2010, 04:28 PM
Zip's Avatar
Zip Zip is offline
...so is it supposed to beep when you lock or unlock? Never heard mine... How do I test it....silly question(?!)
Zip
Old 6th May 2010, 04:30 PM
CliveH's Avatar
Zip
It will if programmed to do so - can be changed with Vagcom (VCDS)
Old 6th May 2010, 05:21 PM
^^^ Wot Clive said. Its a vagcom setting. There was some EU directive around 1999 that said chirping of alarms when arming / disarming wasnt a good idea I believe so whilst Pre face cars up to 1998 chirped by default, late pre face and all facelift cars dont.....
Simple enough vagcom setting, you can also set whether the indicators flash etc etc if you're really bored
