Old 18th July 2016, 09:30 AM
Johnmed's Avatar
Johnmed Johnmed is offline
4 hours. Wow. That is all.
2007 Mini Cooper S R56
Old 18th July 2016, 10:03 AM
Good point (as always) Ainars. I did have a close look at that rubber gasket in the photo and wondered whether it would be re-usable.
Old 18th July 2016, 11:44 AM
Mmm the seal may be an issue. While the engine is out I can get some pics of all the stuff round the back of the throttle body and see what would have to come off.
Old 26th September 2016, 06:41 PM
Attempted to remove the manifold today however, after removing the vacuum hoses and electrical gubbins from the fuel rail as per service manual I just CANNOT lift the fuel rail off. I had squirted WD40 around each injector and they appear to lift fractionally when I pull the rail upwards but even with a small amount of leverage applied it will not come away. I get the feeling that the amount of force needed is close to what would damage the rail Any suggestions?
Old 26th September 2016, 07:48 PM
The fuel rail is in tight. Really, really tight. I think i worked my way round levering gently making progress until it came out. The injectors have rubber seals on them that are snug to say the least, and there's 8 of them clinging on
Old 26th September 2016, 07:53 PM
Thanks Ian, I will try and progresssively lever it up by applying more equal force all round. The injectors certainly lift a mm or so but, of course the effort is only applied to a couple at the time. I really dont want to distort a section of fuel rail!
Old 26th September 2016, 07:55 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
There is a rubbery seal on the 40V intake manifold half. Doesn't seem to suffer too much from dismantling. I put mine back together and torqued down in the correct sequence and it's held nicely
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 28th September 2016, 12:36 PM
All done - a 20" wrecking bar provided the right leverage! I will post a separate thread after hijacking MJ's thread on engine removal!
