D2 - Everything else Anything that doesnt fit elsewhere |
Just a minor bit of trickery I forgot to mention.
The camera has identical wiring (but a different camera body) to that described in great detail by Steamship (Sean) in his thread, as pictured here: You can see the thin cable I referred to and the junction "blob" too. The plugs/sockets (red and yellow) on the end of the camera cable are quite bulky so I trimmed them down with a Stanley knife so they fitted through a slightly smaller (10mm?) hole. Not least because I couldn't easily find anything bigger than a 10mm drill. ![]()
Angle of view from the "first fit" is looking good. Need to crack on with weatherproofing and trimming/refitting the surround.
The rubber diaphragm I intend to use behind the camera for weatherproofing is about 2.5mm thick so will allow for some fine adjustment. Edit: diaphragm fitted, view just as good and minor adjustment possible by slackening screws. Also wired 12v supply into (N/S) reversing light - for reference brown is earth, blue/red +12v. Tested fine, camera fires up and syncs within a second of selecting reverse. Now I need to start on the internal wiring to get the signal to the RNS-D. But first, the surround, though it's just started raining here.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th October 2016 at 01:07 PM. |
Been busy with the dremel; this is the final fit on the rear, though I may take it all off some time to clean up and improve sealing.
I half expected the lens to be slightly blocked by the plastic surround, but it's just clear - so no external trimming required, though I would probably have remounted the camera on thicker backing to avoid that. Pictures of camera view, rear of car (spot the camera and admire LED reversing lights) and finally a close-up of camera from level behind (still see if you can spot it!). Pretty pleased so far, "just" internal wiring to do now. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 12th October 2016 at 02:47 PM. |
The end result is now actually almost a 30mm by 50mm rectangle and is still a bit tight in places and ragged in others so I'm going to rectify that at some point and enlarge it slightly. I'm also missing the top-centre fixing of the backing plate so plan to rectify that too; not quite sure how yet.
Looks a neat job HP. Are the lines adjustable?
Not on that camera, other than physically moving it. I've deliberately chosen to keep it low to see the bumper.
Just tested it to see how it performs at night, seems fine. Near illumination is the LED reversing lights, distant is a street light.
