Old 12th October 2016, 11:59 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Wanted: nearside FL D2 S8 hub carrier
As per title, I require a nearside hub carrier/upright/assembly please.
Part number is N/S 4D0407257Q. Apparently Audi also released a superseded part number that will fit as well, 4D0407253A.
Rich
Old 13th October 2016, 08:57 AM
According to my parts list, the item is termed as "Knuckle, Steering" (which might help searching) and the part numbers are:
1997-99 Right 4D0 407 258L; Left 4D0 407257L
2000 to VIN X005500 - R 4D0 407 258K; L 4D0 407 257K
fm VIN X005501 - R 4D0 407 254 : L 4D0 407 253
2001-03 R 4D0 407 254A : L 4D0 407 253A
This doesnt account for any later changes in the final letter but I hope gives some idea about the part number application. I dont know what physical differences there may be
Old 13th October 2016, 01:59 PM
Conquistador's Avatar
Try looking on Germany ebay also.
You may have looked already, but they are hellishly expensive from Audi. I know, I had to begrudgingly buy one from Audi when the two caliper bolts on mine were completely seized and had to be drilled and cut out.
What's the matter with yours?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 13th October 2016, 07:56 PM
RICKY D's Avatar
Unhappy
Thanks for the help chaps. I've tried finding a second hand unit in the usual places but no luck as yet. Also tried the forum sponsors but they didn't have any in stock.
Car is in getting the suspension kit fitted and the upright snapped whilst extracting the pinch bolt
Currently on back order from Audi, but my mate believes he can source one from TPS for £420
Old 13th October 2016, 08:16 PM
Yeah, the back order took about 10 working days if I remember correctly. You may not have much choice
Price of 'ali' is currently about 70-80p per kg for when you scrap your knackered one
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 13th October 2016, 08:25 PM
I'm now upgrading to steel / cast iron uprights which were installed on v8 3.3 diesel, w12 and all cars with 20" alloys. There will be no problems with pinch bolt in the future. This will require different lower arms.
Old 13th October 2016, 09:02 PM
Where did it break? It may be possible to tig weld it back together, if you can't find a replacement.
Old 10th November 2016, 08:34 AM
SyncroS8 SyncroS8 is offline
I've got a pair...
07989 333437
MG
