Old 6th November 2016, 07:19 PM
woodpoleman woodpoleman is offline
Originally Posted by woodpoleman View Post
I have a 2005 D3 3.0 TDI Quattro with an intermittent fault since May. Car will start but sometimes there's a lag between turning the key and starter kicking in and when out and about after a couple of stops will not start. Turn the key hear relays clicking but starter does not engage. Leave it a while (can be 30 mins - 2 hours) it'll start again. My garage has replaced starter ecu, ignition switch, starter motor. I've replaced engine coolant sensor and starter relays. Audi re-coded ecu, replaced and coded new battery. Audi had the car for two weeks started 4/5 times each day but never drove it so fault never occurred. Any help and ideas will be gratefully received.
Thanks to everyone for their interest and advice which has been appreciated. I'm getting a scan this week and will let you know how it goes.
