Old 18th November 2016, 11:09 AM
I think Ricky is talking about electrical switch inside on the door card that you use to lock/unlock doors not the microswitches in the lock which work when you turn key in the lock. So it should be either switch or wiring fault.
Loke this one http://www.ebay.co.uk/itm/AUDI-A8-D2...cAAOSwcl1XPO2a
But I think it only works with ignition on and only for a short while after ignition switched off so that could be a reason why it was not working while she was waiting.
Old 18th November 2016, 01:10 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Ok Thanks guys.
I was referring to the switch as ainarssems says... I should have been clearer.
The link shows the part I was referring to but I do not need the handle ( or at least I think I don't?)
I wanted to see the price of the switch at my local Audi but it's probably cheaper to get one including handle from ebay.
Old 18th November 2016, 02:06 PM
Its OK . I am easily confused
The door lock switch is item 27 in the picture = 4A0 962 107. or am I on the wrong track again.....
Name:	Door Central Locking Switch.png
