Go Back   A8 Parts Forum > General Motoring > Driving bliss
Driving bliss Best roads? Best music? Whatever makes your 8 the best place to be, share it with us
Old 11th May 2010, 08:12 AM
The key here is how you measure the speed. The speedo at the top end is complete tosh. The law dictates thata speedo should never, ever read slower than you are actually traveling, yet with tyre wear etc it is difficult to predict exactly what speed a car is going so manufacturers er on the side of caution and always make the speedo read faster than you are going. A car with 8mm of tread will be travelling faster than one with 4mm for example. Having said that, the engine ECU has a far more accurate idea of the speed you're doing, and as its thoughts arent governed by law, it is its decision when you have hit 155.
Here is a shot of a 2002 S8 hitting the redline in fourth, about to drop into fifth - Preface changes promptly by 7000rpm, facelift tends to drift over a extra hundred...
Speedo says 145, but really it'll be about 130.
And then here is the 'speed limiter' kicking in. As Ben says, the throttle just stops going any faster, its a very smooth numb feeling as the car just says enough is enough (Sorry its so fuzzy, the car was smooth, but I knocked the camera whilst taking the shot)
Speedo topped out at 177mph, but we know as it was the limiter, it was actually 155mph, so quite some difference....
Its worth noting that it takes quite a long time to get this speed up, at the top end every extra mph is a battle against extra wind resistance. Although there is a theoretical maximum in the 180's, I'm struggling to visualise it actually getting there......
ID:	1075   Click image for larger version
