Old 27th November 2016, 05:41 PM
Albert_Swafega Albert_Swafega is offline
Default ESP then Air Suspension light ... again
Well, this car is now officially getting on my nerves.
As you may have seen, since i bought her, i've had the suspension compressor & accumulator done, then just done the electric coolant pump recently.
Driving along today, i caught the rear right wheel on the kerb at an awkward junction, it climbed the kerb then dropped.
Within 10 minutes or so, the ESP light came on, followed by the air suspension light. Immediately i thought the compressor had failed...again, but upon inspection the car hasn't lost level. I can raise the car, then lower it back no problem. The fault clears when i turn the ignition off then restart. But she drives poorly as soon as the ESP light comes on (rough feeling ride).
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 30 34 36 3B 42 46 52 53
55 56 5F 62 69 6C 6D 6F 72 81 8F 90
VIN: WAUZZZ4H Mileage: 175759km-109211miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDTA) Labels: 059-907-401-V2.clb
Part No SW: 4H0 907 401 HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004
Revision: 53H37---
Coding: 0A2A4012052601020800
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114H0907401 001010
ROD: EV_ECM30TDI0114H0907401.rod
VCID: 61D0B5F72149538A70AEFB9-8034
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 AA HW: 0BK 927 156 L
Component: 0BK 30 TDIRdW H08 0002
Revision: --H08---
Coding: 001111
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_AU64.rod
VCID: 6FF4C3CFE79DF5FAF63A1D1-803A
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Revision: -------- Serial number: --------------
Coding: 60E5A30006A7C500E300
Shop #: WSC 02312 785 00200
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_AU64.rod
VCID: 317005B73129A30AA08ECB9-8064
1 Fault Found:
0137 - Function Restriction due to Faults in Other Modules
U1113 00 [136] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 13
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BB HW: 4H0 907 064 AB
Component: BCM2 2.0 H23 0333
Revision: 00002001
Coding: 05B72F00000000000000
Shop #: WSC 00505 210 91477
VCID: 6AC2D2DBDC7F1052A14444D-803E
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 F HW: 4H0 959 760 F
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00001002231900
Coding: 0038320000047201000001010101102130313131282020
Shop #: WSC 02313 785 00200
VCID: 367A36ABD84784B2F57C80D-8062
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 D HW: 4H0 820 043 D
Component: Klima 3 Zonen H14 0061
Coding: 3621002800
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_AU64.rod
VCID: 2150F5F761C9138A302EBB9-8074
1 Fault Found:
0130 - Motor for Left Side Window Defrost Flap
B10D7 21 [008] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 10
Mileage: 175489 km
Date: 2016.11.21
Time: 14:45:11
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000741397
Coding: 26002010C034AFE18B810007A0001D0C009DC30A0701010180 0008402000
VCID: 317005B73129A38AA08ECB9-8064
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 100708 H32 0040
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 HW: 4H0 941 531
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55931034303629
Coding: 310302
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000.rod
VCID: 37643BAFDF4D7D3AEE4AB51-8062
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG001932A
Coding: 30314246323430303038554A305234483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU64.rod
VCID: 367A36ABD8478432F57C80D-8062
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405F6U4L4D8U0
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B00TMOA1AK
Crash sensor for side airbag; rear; driver side:
Serial number: 3515JRB406504QLU4GIX
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525JRB406504QLU68IS
Crash sensor for front airbag; driver side:
Serial number: 3554VRB405F070UGL1FS
Crash sensor for front airbag; front passenger side:
Serial number: 3564VRB405F070UGKPGA
1 Fault Found:
1050117 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 14
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815JL10001C
Coding: 000034
Subsystem 1 - Part No SW: 4H0 951 528 G HW: 4H0 951 528 G
Component: E221 - MFL H04 0009
1 Fault Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 175709 km
Time Indication: 0
Date: 2016.11.27
Time: 13:55:36
Freeze Frame:
(no units): 36.0
Text: 24A326013F014F4006
Clock: 38:01 h
Text: O@v %£&
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 910 D HW: 4H0 920 910 A
Component: TDieGB------- H30 0297
Revision: 26110011 Serial number: 658161210593046
Coding: 33A708001B002600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 2558E1E775E1FFAA4C164F9-8070
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H04 0210
Serial number: 1101209001575
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000074157
Coding: 00CD077D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 347E0CA3CE3B9622CB68EA5-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005659395052
Voltage stabilizer:
1 Fault Found:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 175513 km
Date: 2016.11.23
Time: 19:35:08
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000009258
Coding: 01010101000000000000000202
VCID: 64DEBCE33E5B46229B889A5-8030
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008001
Shop #: WSC 01236 210 01865
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU64.rod
VCID: 2C4E14C3160BCEE293D8325-8078
2 Faults Found:
677124 - Ride-Height System
C1047 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 13
Mileage: 175600 km
Date: 2016.11.26
Time: 12:10:24
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002231940
Coding: 00383B0000057201000001010101102130313131202020
1 Fault Found:
03332 - Motor for Height Adjustment
Freeze Frame:
Fault Status: 01101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 224
Mileage: 175513 km
Time Indication: 0
Date: 2016.11.23
Time: 19:58:54
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA310090CJ0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 6CCED4C3D68B0EE2D358725-8038
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000110310280
Coding: 011F12205E21628202080002
VCID: 3C6E2483E66B5EE20338425-8068
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0140221010
Coding: 011B0E2200B93C81B320C78408010000000000000000000000 0000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H11 0080
Coding: 010000
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000111182888
VCID: 3B6C279FE36559DA0A32591-806E
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 D HW: 4H0 907 801 A
Component: EPB-4 H03 0010
Revision: -------- Serial number: 00000000028373
ASAM Dataset: EV_ParkiBrake 001021
ROD: EV_ParkiBrake_AU48.rod
VCID: 2940EDD719F9DBCA68FE139-807C
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0012
Serial number: 101208-0004-010
Coding: 11116F101000A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4H0 035 061 G HW: 4H0 035 061
Component: Radio U DAB H52 0097
Revision: AB001007 Serial number: 440L.0A7504196
Coding: 010103020100000001
VCID: 2252FAFB64CF08122934ACD-8076
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 666 F HW: 4H0 035 666 C
Component: H-BN-EU H41 0239
Revision: -------- Serial number: 058L 0A7502571
Coding: 020101000001F1EF45108B1E00000003E001010000000000
VCID: 2C4E14C3160BCE6293D8325-8078
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Subsystem 3 - Part No SW: 4H2 919 600 D HW: 4H2 919 600
Component: E380 BDT D4 H09 0063
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 175492 km
Time Indication: 0
Date: 2016.11.21
Time: 18:23:17
Freeze Frame:
Text: ÿ
Text: ÛJ
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000110119863
Coding: 010F12204021628202080002
VCID: 3A62229BEC5F60D2112454D-806E
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 4H0 907 383 C HW: 4H0 907 383 C
Component: Anhaenger H07 0100
Revision: 5H001001 Serial number: 00000137048799
Coding: 0100000000000000
VCID: 2D4819C72D11C76A84A6279-8078
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H04--- Serial number: 525 PA8J0YD0IX
Coding: 1022002
VCID: 65D8A1E73561332A8C968F9-8030
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 341000088
Coding: 0210044001
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3B6C279FE365595A0A32591-806E
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000018573
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63DCBFFF3B55419A6282911-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000110119831
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H05 0081
Revision: 0R0D5012 Serial number: SN101109 0163
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
1 Fault Found:
12584197 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 14
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70F6C0B3FAA3EA02EF00065-8024
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 14
Mileage: 175709 km
Date: 2016.11.27
Time: 13:55:36
End-------------------------(Elapsed Time: 05:47)--------------------------
2011 A8 Executive 3.0 TDI Quattro
Old 28th November 2016, 12:01 PM
Has the wheel height sensor on the wheeel that took a knock been dis lodged /upset in some way .
All the other modules flagging codes are a consequence of the ride height issue by the looks of it .
Old 28th November 2016, 03:55 PM
I've had the wheel off, and all looks good to be honest.
It's the first time I've had the wheel off, but it has the ride height sensor similar to my old discovery, and it looks intact.
Old 28th November 2016, 08:25 PM
Just having a look at the codes and time stamp data , it's hard to say what's flagged what first .
Save that log , and do full clear down , see what comes back on after that , if ride height is still not working check ride height readings either via voltage or mm readings from each wheel , try in activations that the compressor can run .
I'm just wondering if steering head angle sensor will stop ride height from working .
Let's see how we look after the full clear down .....
Old 30th November 2016, 03:47 PM
Well, cleared, took round block, and as full scan:
Code:
Wednesday,30,November,2016,16:54:09:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUZZZ4H   License Plate:
Mileage: 175821km-109250mi   Repair Order:
VIN: WAUZZZ4H6BN013761   Mileage: 175821km-109250miles
08-Auto HVAC -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
   Revision: 53H37---
   VCID: 61D0B5772149538A70AEFB9-8034
2 Faults Found:
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Readiness: 0 0 0 0 1
   Revision: --H08---
   Coding: 001111
   VCID: 6FF4C34FE79DF5FAF63A1D1-803A
   VCID: 317005373129A30AA08ECB9-8064
1 Fault Found:
          U1113 00 [137] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
   Revision: 00002001
   VCID: 6AC2D25BDC7F1052A14444D-803E
   VCID: 367A362BD84784B2F57C80D-8062
   Coding: 3621002800
   VCID: 2150F57761C9138A302EBB9-8074
   Coding: 26002010C034AFE18B810007A0001D0C009DC30A07010101800008402000
   VCID: 317005373129A38AA08ECB9-8064
   Coding: 0045F7
   Coding: 025523
   Coding: 020300
   Coding: 310302
   VCID: 37643B2FDF4D7D3AEE4AB51-8062
   VCID: 367A362BD8478432F57C80D-8062
1 Fault Found:
1050117 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
   Coding: 000034
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Time Indication: 0
                    Date: 2016.11.30
                    Time: 16:46:30
             Freeze Frame:
                    Text: ÛJ
                    Text: a
   ROD: EV_RBD4K.rod
   VCID: 2558E16775E1FFAA4C164F9-8070
   Analog_clock:
   ROD: EV_RBD4K.rod
   Analog_clock:
   Coding: 00CD077D00
   VCID: 347E0C23CE3B9622CB68EA5-8060
   Voltage stabilizer:
   VCID: 64DEBC633E5B46229B889A5-8030
   Coding: 008001
   VCID: 2C4E1443160BCEE293D8325-8078
1 Fault Found:
          U1112 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
   ROD: EV_SARA.rod
   VCID: 6CCED443D68B0EE2D358725-8038
   VCID: 3C6E2403E66B5EE20338425-8068
   Coding: 011B0E2200B93C81B320C784080100000000000000000000000000000000
   Coding: 010000
   VCID: 3B6C271FE36559DA0A32591-806E
   VCID: 2940ED5719F9DBCA68FE139-807C
   VCID: 2252FA7B64CF08122934ACD-8076
   VCID: 2C4E1443160BCE6293D8325-8078
   VCID: 3A62221BEC5F60D2112454D-806E
   VCID: 2D4819472D11C76A84A6279-8078
   Coding: 1022002
   VCID: 65D8A1673561332A8C968F9-8030
   Coding: 0210044001
   VCID: 3B6C271FE365595A0A32591-806E
   Coding: 220000
   ROD: EV_Ambie.rod
   VCID: 63DCBF7F3B55419A6282911-8036
   ROD: EV_RGS_L.rod
1 Fault Found:
          U1113 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
   ROD: EV_RGS_R.rod
   VCID: 70F6C033FAA3EA02EF00065-8024
1 Fault Found:
          U1113 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
End-------------------------(Elapsed Time: 05:44)--------------------------
All fault priorities are 6 except the steering able sensor which is priority 2, does that mean that's the cause?
Old 1st December 2016, 12:53 PM
Mmmm i think steering head angle sensor is the first i would be looking at .....lots of other modules will need info from it on the network .
If you go into steering head angle and go to the angle data block is there any reading from it when you turn steering left and right .
Old 1st December 2016, 12:56 PM
And .......... if you are getting readings does it show a zero figure when the wheel is in its straight ahead position ?
Old 4th December 2016, 01:40 PM
Well, being an amateur, and my first Audi.......
I managed to watch the sensor measurements, and all appeared to climb and fall as i raised and lowered the suspension.
I managed to watch the angle sensor reading whilst turning the wheel, and it did indeed show "0" when pointing straight.
As the car is under warranty from where i bought it, i've arranged to take it in on Monday.
Low & behold, took the car out today, NO ESP LIGHT, NO SUSPENSION LIGHT!!
The strange thing is, the light has not been on since i parked on a very steep hill yesterday. And i recall when it first came on, i was going down a very steep hill in Sheffield.
Coincidence?
I'll take the car in as planned tomorrow, but i suspect they'll say if they can't replicate the fault, they can't fix it.
Let's see if it comes back on.
