Go Back   A8 Parts Forum > A8 D4 > D4 - Axles, Brakes, Suspension and Steering
D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc.
Old 30th November 2016, 03:47 PM
Albert_Swafega Albert_Swafega is offline
Well, cleared, took round block, and as full scan:
Code:
Wednesday,30,November,2016,16:54:09:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUZZZ4H   License Plate:
Mileage: 175821km-109250mi   Repair Order:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 30 34 36 3B 42 46 52 53
          55 56 5F 62 69 6C 6D 6F 72 81 8F 90
VIN: WAUZZZ4H6BN013761   Mileage: 175821km-109250miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDTA)       Labels: 059-907-401-V2.clb
   Part No SW: 4H0 907 401     HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 0A2A4012052601020800
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114H0907401 001010
   ROD: EV_ECM30TDI0114H0907401.rod
   VCID: 61D0B5772149538A70AEFB9-8034
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
4699 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 AA    HW: 0BK 927 156 L
   Component: 0BK 30 TDIRdW H08 0002
   Revision: --H08---
   Coding: 001111
   ASAM Dataset: EV_TCMALX51011 001013
   ROD: EV_TCMALX51011_AU64.rod
   VCID: 6FF4C34FE79DF5FAF63A1D1-803A
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
   Component: ESP PREMIUM   H10 0273
   Revision: --------    Serial number: --------------
   Coding: 60E5A30006A7C500E300
   Shop #: WSC 02312 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_AU64.rod
   VCID: 317005373129A30AA08ECB9-8064
1 Fault Found:
0137 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 BB    HW: 4H0 907 064 AB
   Component: BCM2 2.0      H23 0333
   Revision: 00002001
   Coding: 05B72F00000000000000
   Shop #: WSC 00505 210 91477
   VCID: 6AC2D25BDC7F1052A14444D-803E
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
Address 06: Seat Mem. Pass (J521)       Labels: None
   Part No SW: 4H0 959 760 F    HW: 4H0 959 760 F
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00001002231900
   Coding: 0038320000047201000001010101102130313131282020
   Shop #: WSC 02313 785 00200
   VCID: 367A362BD84784B2F57C80D-8062
Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
   Part No SW: 4H0 820 043 D    HW: 4H0 820 043 D
   Component: Klima 3 Zonen H14 0061
   Coding: 3621002800
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 2150F57761C9138A302EBB9-8074
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000741397
   Coding: 26002010C034AFE18B810007A0001D0C009DC30A07010101800008402000
   VCID: 317005373129A38AA08ECB9-8064
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 100708  H32 0040
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531     HW: 4H0 941 531
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55931034303629
   Coding: 310302
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 37643B2FDF4D7D3AEE4AB51-8062
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG001932A
   Coding: 30314246323430303038554A305234483053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_AU64.rod
   VCID: 367A362BD8478432F57C80D-8062
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405F6U4L4D8U0
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B00TMOA1AK
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515JRB406504QLU4GIX
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525JRB406504QLU68IS
   Crash sensor for front airbag; driver side:
   Serial number: 3554VRB405F070UGL1FS
   Crash sensor for front airbag; front passenger side:
   Serial number: 3564VRB405F070UGKPGA
1 Fault Found:
1050117 - Databus
          U1123 00 [008] - Received Error Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815JL10001C
   Coding: 000034
   Subsystem 1 - Part No SW: 4H0 951 528 G    HW: 4H0 951 528 G
   Component: E221 - MFL  H04 0009
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Time Indication: 0
                    Date: 2016.11.30
                    Time: 16:46:30
             Freeze Frame:
                    Text: ÛJ
                    Text: a
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 910 D    HW: 4H0 920 910 A
   Component: TDieGB------- H30 0297
   Revision: 26110011    Serial number: 658161210593046
   Coding: 33A708001B002600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   VCID: 2558E16775E1FFAA4C164F9-8070
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H04 0210
   Serial number: 1101209001575
   ROD: EV_RBD4K.rod
   Analog_clock:
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000074157
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewUDS 001025
   ROD: EV_GatewUDS_AU57.rod
   VCID: 347E0C23CE3B9622CB68EA5-8060
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005659395052
   Voltage stabilizer:
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000009258
   Coding: 01010101000000000000000202
   VCID: 64DEBC633E5B46229B889A5-8030
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008001
   Shop #: WSC 01236 210 01865
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_AU64.rod
   VCID: 2C4E1443160BCEE293D8325-8078
1 Fault Found:
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00001002231940
   Coding: 00383B0000057201000001010101102130313131202020
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA310090CJ0
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   VCID: 6CCED443D68B0EE2D358725-8038
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000110310280
   Coding: 011F12205E21628202080002
   VCID: 3C6E2403E66B5EE20338425-8068
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0140221010
   Coding: 011B0E2200B93C81B320C784080100000000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H11 0080
   Coding: 010000
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000111182888
   VCID: 3B6C271FE36559DA0A32591-806E
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 D    HW: 4H0 907 801 A
   Component: EPB-4         H03 0010
   Revision: --------    Serial number: 00000000028373
   ASAM Dataset: EV_ParkiBrake 001021
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2940ED5719F9DBCA68FE139-807C
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0012
   Serial number: 101208-0004-010
   Coding: 11116F101000A300
   ASAM Dataset: EV_HeadlRegulBasic 005001
   ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4H0 035 061 G    HW: 4H0 035 061
   Component: Radio U DAB   H52 0097
   Revision: AB001007    Serial number: 440L.0A7504196
   Coding: 010103020100000001
   VCID: 2252FA7B64CF08122934ACD-8076
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 4H0 035 666 F    HW: 4H0 035 666 C
   Component: H-BN-EU       H41 0239
   Revision: --------    Serial number: 058L 0A7502571
   Coding: 020101000001F1EF45108B1E00000003E001010000000000
   VCID: 2C4E1443160BCE6293D8325-8078
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Subsystem 3 - Part No SW: 4H2 919 600 D    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0063
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000110119863
   Coding: 010F12204021628202080002
   VCID: 3A62221BEC5F60D2112454D-806E
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 4H0 907 383 C    HW: 4H0 907 383 C
   Component: Anhaenger     H07 0100
   Revision: 5H001001    Serial number: 00000137048799
   Coding: 0100000000000000
   VCID: 2D4819472D11C76A84A6279-8078
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J0YD0IX
   Coding: 1022002
   VCID: 65D8A1673561332A8C968F9-8030
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 341000088
   Coding: 0210044001
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B6C271FE365595A0A32591-806E
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000018573
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63DCBF7F3B55419A6282911-8036
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000110119831
Address 81: Gear Shift (J587)       Labels: None
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H05 0081
   Revision: 0R0D5012    Serial number: SN101109  0163
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono.rod
Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
1 Fault Found:
12584197 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70F6C033FAA3EA02EF00065-8024
1 Fault Found:
          U1113 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 175821 km
                    Date: 2016.11.30
                    Time: 16:46:30
End-------------------------(Elapsed Time: 05:44)--------------------------
All fault priorities are 6 except the steering able sensor which is priority 2, does that mean that's the cause?
2011 A8 Executive 3.0 TDI Quattro
