Just to add my 2p - I have the same battery that Marcin linked to. I bought mine from www,puredrivebatteries.co.uk.
Oh, and yes, I also had some battery issues after the car was sitting idle during the gearbox repair. ![]() |
IThis maybe worth a look before you change the battery , in battery regulation module find the s o c block ....state of charge just make a note of the battery charge percentage .
Then have a look at the alternator charge output in Amps , from memory engine running with no loads on its about 20 amps or so , fit and code the new battery in and do same tests . Parasitic drains can be hard to sort and sometimes tie you in knots , I find knowing how much is being drawn helps a little in understanding what it can be . I've found trying to use a multimeter in series with the battery heavy cables is hard , the surge up when trying to connect the meter often pops the multi meter fuse , just trying to lock the car pulls out alot of Amps ......how do the techs on here go about it ?? I use a shunt across the lead and ' tap up ' off that with a multimeter or use the pico scope low amps clamp and watch the draw wave form ,Roll the boot latch over and lock the car and watch as the amps reduce as modules go to sleep . So if you have some kind of amps draw it's a case of pulling fuses till you see the draw diminish .....some folk do voltage drop across fuses but you end up at the same result by pulling them . Thing is ....sometimes one fuse can be powering a system that has a lot of power consumers on it so you still haven't narrowed all the way down when you pull the fuse and see the amps draw go . My own car had an issue while back flagging quiescent current exceeded ....stage 1 .... stage 2 and so on whilst parked up over night , I left it at work hooked up to the pico on 20amp range clamp over a 24 hour time base and checked scope trace next day . Periodically it would pull out 9 amps tailing off to 4 amps for around a 6 minute slot , then go back to sleep ......it could do this 10 / 12 times throughout a 12 hour period , then in the morning I would get the battery low message when ignition turned on . Anyone one to have a pop at what it was ........ Last edited by Mechcanico Lee; 19th December 2016 at 09:52 PM. |
Air suspension?
This
Periodically for a period of time after locking the car will wake up and check/re level the air suspension using the big reservoir at the back of the car for topups. I think this goes on for 10 hours or until the pressure in the tank is lost. The air compressor does not run, but several ECUs are powered up during the process. I have intermittent battery issues, but I am putting that down to lack of use, I usually take out more on my short journeys that I put back in. I did some testing and found that after switch off and before the car fully goes to sleep it draws around 10 amps before it finally drops to almost nothing.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 20th December 2016 at 07:08 AM. |
Yeah, I am hoping that its just a battery, but I have been aware that air suspension does cause hassles like this, I went out this morning and disconnected the CTEK as its fully charged the battery, so have put the car in LIFT mode to see what happens as it will visibly be easier to tell later if the car has dropped.
Interestingly, when I first turned her on the words SAFE came up in the binnacle where you trip distance would usually be, and a loud clicking with a light flicker inside the glovebox I turned her off, then on again, and both had gone and the car seemed normal once more. Hopefully the new battery and VCDS will be here before the light dies away and I can swap them over |
I'll keep my fingers crossed
With mine ......... give you a clue ........ its worse when its wet or been raining .., or i have washed it
KESSY, something to do with water ingress in the external lock buttons?
Correct Matty
![]() With car locked up for more than 15 mins or so ( better at night so you can see display around gear stick ) just press the outer door handle button and see if display around gear stick or hazard switch lights up ....and how long it stays lit up . Because even when they go back off the car is still drawing some current till it goes fully to sleep again |
Right, my VCDS finally arrived today - just managed to get outside in the pitch black and do a scan, almost wish I hadn't... looks like loads of errors!
I can see a lot are voltage related, so hope that the new battery solves that, will drop it in and code tomorrow, if not, it looks like it'll be something else. Some of the errors are a little concerning in that there was no CEL light on the dash, so how could it have engine errors and do that? This was from an auto scan, I also checked the individual modules for the Engine (which it read ok) and the gearbox (also) so don't know why they show as cannot be reached below? Thursday,22,December,2016,04:03:29:44654 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 16.8.4.2 (x64) Data version: 20161129 DS267.0 www.Ross-Tech.com VIN: WAUZZZ4E78N003545 License Plate: Mileage: 110780km-68835mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1D 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77 VIN: WAUZZZ4E78N003545 Mileage: 110780km-68835miles 00-Steering Angle Sensor -- Status: Cannot be reached 1100 01-Engine -- Status: Cannot be reached 1100 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Cannot be reached 1100 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Cannot be reached 1100 31-Engine other -- Status: Cannot be reached 1100 15-Airbags -- Status: Cannot be reached 1100 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Cannot be reached 1100 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: Cannot be reached 1100 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 02: Auto Trans Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes Cannot be reached ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 A Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0G9332471 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BE07CAEBBD0582D1-800C Subsystem 1 - Part No: 4E0 905 852 E Component: ELV 2040 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 24 Mileage: 110784 km Time Indication: 0 Date: 2016.12.21 Time: 18:55:20 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300JT077588153 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 3A7ABD4275F1F792C7-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000047342 Subsystem 3 - Serial number: 0108.10.070000000100010149ˇ Subsystem 4 - Serial number: 010149ˇ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 239 Mileage: 110788 km Time Indication: 0 Date: 2016.12.21 Time: 18:58:29 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000132966 Coding: 0123001 Shop #: WSC 02311 785 00200 VCID: 1C365BDADF05A9A235-8048 3 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 12 Reset counter: 229 Mileage: 109710 km Time Indication: 0 Date: 2016.12.01 Time: 20:28:03 Freeze Frame: Voltage: 14.50 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 60 Reset counter: 24 Mileage: 109710 km Time Indication: 0 Date: 2016.12.01 Time: 20:31:52 Freeze Frame: Voltage: 14.30 V 01274 - Air Flow Flap Positioning Motor (V71) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 252 Mileage: 109795 km Time Indication: 0 Date: 2016.12.03 Time: 12:50:09 Freeze Frame: Voltage: 14.10 V Temperature: 21.0∞C (no units): 62.0 (no units): 65.0 Temperature: 9.0∞C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Cannot be reached Unable to communicate with address 09. Are you sure the doors are unlocked? ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00481 210 83110 VCID: 2B5488064AAB5E1A4C-807E No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276V7600354 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Cannot be reached ------------------------------------------------------------------------------- Address 16: Steering wheel Cannot be reached ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 M HW: 4E0 920 951 M Component: KOMBIINSTR. VDO H83 0620 Revision: D03 Serial number: AUDID3G9000135 Coding: 0048423 Shop #: WSC 60756 001 1048576 VCID: 2F6C9C16BEB3223A60-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B07A0183FF Coding: F5F59FFF707E1E00 Shop #: WSC 02313 785 00200 VCID: 2D50861EB4BF502A52-8078 No fault code found. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 10102007110845 Shop #: WSC 00000 000 00000 VCID: 1F4C6CD6CE13B2BAD0-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046006 Serial number: AUZ5ZBG3498338 Shop #: WSC 00000 000 00000 VCID: 1A3A5DC2D531D79227-804E No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000060119 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C82A2EB8E7C44AA6-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Cannot be reached ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 2446633AE77591628D-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H50 1060 Revision: 00000000 Serial number: 364J-077721737 Shop #: WSC 00385 210 90050 VCID: 3B74B8467ACBCE9ADC-806E 1 Fault Found: 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 8 Reset counter: 4 Mileage: 109877 km Time Indication: 0 Date: 2016.12.04 Time: 13:51:16 Freeze Frame: Hex Value: 0x5846 Hex Value: 0xBFD6 Hex Value: 0x0AFF Hex Value: 0x0955 ------------------------------------------------------------------------------- Address 38: Roof Electronics Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 F Component: T¸rsteuer.FS BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Cannot be reached ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 D HW: 4E0 035 466 Component: BO_D3 H06 0320 Revision: 20S00002 Serial number: 02504070009182 Coding: 0000027 Shop #: WSC 02313 785 00200 VCID: 275C743696437A7AA8-8072 Subsystem 1 - Part No: 4E0 910 465 B Component: BO_D3_SLAVE H31 0310 Subsystem 2 - Serial number: 02407070006986 Subsystem 3 - Serial number: 0224.07.070000000100030024ˇ Subsystem 4 - Serial number: 030024ˇ No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000008403 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 F Component: T¸rsteuer.BF BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Cannot be reached ------------------------------------------------------------------------------- Address 55: Headlight Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396J5077580768 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 31689A6EA88734CA76-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300801312402 Coding: 0000003 Shop #: WSC 00579 210 91783 VCID: 25407E3EEC4F686A9A-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000013901 Shop #: WSC 00385 210 90050 VCID: 204E6F2AF36D8D42E9-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 0331216G1R Coding: 344530393135313035412056413030333331323136473152 Shop #: WSC 13149 000 104857 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: T¸rsteuer.HL BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000700054053 Coding: 0252329 Shop #: WSC 02313 785 00200 VCID: 204E6F2AF36D8D42E9-8074 1 Fault Found: 01299 - Diagnostic Interface for Data Bus (J533) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 2 Reset counter: 1 Mileage: 109725 km Time Indication: 0 Date: 2016.12.02 Time: 15:49:45 Freeze Frame: (no units): 255.0 Voltage: 0.00 V (no units): 27.0 Temperature: 0.0∞C Temperature: 0.0∞C Temperature: 0.0∞C Temperature: 0.0∞C ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H46 0630 Revision: 00000000 Serial number: 00000710010631 Shop #: WSC 12336 024 394758 VCID: 3662A97241E913F223-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: T¸rsteuer.HR BRM005 0180 Coding: 0032623 Shop #: WSC 02313 785 00200 VCID: 1E3251D2C919BBB2DB-804A 1 Fault Found: 02124 - Exterior Door Handle Switch 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 209 Mileage: 109696 km Time Indication: 0 Date: 2016.12.01 Time: 20:27:22 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08740727500405 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 23446026E27B965AF4-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4F1-910-336.lbl Part No SW: 4F1 910 336 D HW: 4F1 862 335 Component: BTA H09 1120 Revision: 00H09000 Serial number: 00000007518615 Coding: 0060001 Shop #: WSC 02313 785 00200 VCID: 25407E3EEC4F686A9A-8070 No fault code found. End-------------------------(Elapsed Time: 03:31)-------------------------- Last edited by 1781cc; 21st December 2016 at 06:24 PM. |
