Old 29th December 2016, 12:00 PM
green A8 green A8 is offline
Default Testing seat adjustment motors
I seem to remember that this can be done but have never tried.
I'm just wondering if I can test the adjustment motors in a pair of front seats I've been offered, with them out of the car. The seats owner tells me that I need to connect power to the red two pin connector block. Is this correct I don't want to set the air bags off by accident The seats are Recaro type taken out of a 1998/9 PF S8
Thanks in advance for any help offered
Old 29th December 2016, 01:00 PM
Yes you can. The airbag is the small yellow connector so avoid that and you'll be fine. I have a 'pondering chair' in the workshop which is a Recaro mounted on castors, with the adjustment motors hooked up to a battery so it still moves I'll grab a pic of the connector this afternoon if I get a chance
Old 29th December 2016, 07:17 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
I gotta get me one of those!!
My pondering chair is an old bar stool from our old kitchen
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 29th December 2016, 07:30 PM
johnny_quattro's Avatar
MJ - I'd be quite interested to see this photo too. You may or may not be aware that I've recently swapped the seats in my A8L and have the front and rears sitting in a friend's garage, awaiting sale or 'reallocation'. Castors sound like a great idea. The old seats are heated too although this may drain the supply battery at an alarming rate. Ideally it would be great if I could adjust the seat AND heat it if the need arises - a friend of mine is interested in having them for his man cave ;-)
Cheers, John G
I thought this was a pondering chair.
I've considered making a chair for my workshop from a D2 Recaro seat a few times. I was thinking I might try combining the base from an old gas-lift chair to raise it to bench height. Not sure how stable that would be though ... might need stabilisers to prevent it toppling
Old 29th December 2016, 07:48 PM
I think that both TinTin and Roberto both have re-used D2 recaros in this way for recreational seating!
