Old 1st January 2017, 10:45 AM
1781cc 1781cc is offline
Cool, thanks for this, however, what number do I use for the first of the 3 digits as the 5.2L engine isn't listed?
Old 1st January 2017, 12:02 PM
Good question! I would guess at the 6.0 W12 as the S8 and W12 share the same brakes?
Old 1st January 2017, 12:07 PM
The coding shouldn't need changing from whatever it is from the factory, but you can view it and see if it makes sense with the chart on the rosstech website anyway. You just need to adapt the thickness - 12 is a typical value.
Old 1st January 2017, 12:10 PM
The rear calipers on the D3 are identical on every model, single piston with EPB, only the carrier changes to accommodate the different size discs. So I agree with Neil, use W12 coding.
Matt
Old 1st January 2017, 12:30 PM
Sweet, thanks peeps, will add to my list of stuff to do tomorrow - along with working out how to get the horn to beep when I lock it
Old 1st January 2017, 02:03 PM
Is the above same for ceramic brakes?? Do they share same calipers and pad thickness??
Three months ago when doing work on rear axle (dif oil, wheel bearings and pads) and since then I get quiet often brake pads warning.
But...even when I stopped while the warning light was still on the dash, VCDS showed no faults whatsoever for pads, no faults in ABS ECU at all.
So I'm thinking either wiring got damaged which is kind of not possible as the rear pads have no wear sensors, or adaptation of new pads hasn't been accepted??
I know that RS6 ceramic brakes use same rear pads what S8.
I can fairly accurately measure remaining pad on the car, but if there is no faults would you say pad warning is down to the adaptation??
It was quiet for some time, then it started coming on after some driving and sometimes as soon I start the engine.
Thanks guys
Old 1st January 2017, 06:23 PM
I had similar problems on my D3 - fixed in the end with a brand new EPB module
Old 1st January 2017, 07:14 PM
Interesting
What were your symptoms? Any faults on VCDS?
Cheers Paul
