Old 8th January 2017, 04:43 PM
Simonbartlett Simonbartlett is offline
I have a cheap lead in the garage from the T5 Caravelle but it was a nightmare to get connected. From memory trouble setting ports took me bloody ages then I lost interest. I guess a genuine one would be easier
Owner of a 2008 A8 3.0tdi SE
Old 18th January 2017, 10:27 AM
ulfilias ulfilias is offline
Can't see why ODBeleven couldn't do this.
https://obdeleven.com/
I've got one in my ashtray for doing quick simple things and reading fault codes etc on the move. VCDS is better and more hand holdy for most things, but a simple thing like this it would be ideal at tweaking. You'd need the "pro" version but then, you do for most things and if you've got the dongle then it's no biggie!
I've not tried it for this, but can if someone is interested.
Lee
Old 18th January 2017, 03:01 PM
[quote=ulfilias;123012]Can't see why ODBeleven couldn't do this.
Lee[/QUOTE
Looks like a cheap alternative if it can do a bit of coding. If anyone has one and could try it that would be great. Thanks
Old 20th January 2017, 10:41 AM
It's good on modules and fault codes and have a nice interface there, however while It can certainly do coding, but it's enter a channel, enter a number!
I plugged my vagcom in to look at working out what relevant settings would be, and tried a couple of net searches to look up info, but I couldn't seem to work it out?!?!
Mines an 2005 with Bi-Xenon's. Going into 55 Headlamp Range, all i could fine was settings for leveling, codes to say what sort of light you have etc.
Adaption (10 which is confusing) doesn't have a channel 10 on mine, so it's not that
So i haven't been able to test this!
Lee
Old 20th January 2017, 12:12 PM
Thanks for trying
Old 8th March 2017, 09:05 PM
I now have my obdeleven so will try doing this at the weekend, Any ideas where to start ?
Old 21st June 2017, 04:18 PM
Going to Belgium this weekend, has anyone managed to do this and has any tips ?
